Last updated by Prosenjit Barman 11 months, 2 weeks ago.
October 2, 2024 at 5:09 pm #16246907
alinaM-7
We have a site with automatically translated Spanish content. We are now spot-checking the Spanish and making a few manual edits in the translation editor.
Small manual text edits are taking anywhere from 2-10 minutes to show up on the front end, even though I can see they are saved in the back end. After making a translation edit in the Advanced Translation editor and clicking 'Complete Translation', the site redirects to a page in my recent history, but NOT the page I was just editing.
Is it normal for small manual text edits to take 2-10 minutes to show up on the front end?
Is it expected for the site to redirect to another page in my history after clicking 'Complete Translation' in the Advanced Translation editor?
Are you able to take a look at our configuration or are there any known issues?
October 2, 2024 at 5:12 pm #16246969
alinaM-7
Adding a little more detail. Sometimes the Advanced Translation Editor appears to get stuck and the "Complete Translation" button keeps animating indefinitely. At that time, in the Console I can see this error:
Uncaught (in promise) TypeError: Failed to construct 'URL': Invalid URL
at application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:65:5321
at r (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:18:20499)
at Generator._invoke (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:18:20287)
at Generator.next (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:18:20679)
at on (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:55:28173)
at i (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:55:28359)
at application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:55:28439
at new Promise (<anonymous>)
at Object.<anonymous> (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:55:28319)
at Object.completedUrl (application-7d03af4f2d5fa2f745580e64e6a43306d45a0f663eda1494a66fa4438938a80d.js:65:5642)
October 3, 2024 at 5:35 am #16247870
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
I understand the issue you're experiencing. Typically, translating a segment or completing an entire translation shouldn't take much time. However, factors such as content size and server configuration can cause delays. That said, based on your site’s configuration and the information in our system, there shouldn't be any issues with the translation editor. Could you please try the following steps and see if they make any difference in the result?
1. Please go to Settings > General from your Dashboard and ensure that the site URL and WordPress URL are configured correctly. Both should point to the main domain.
2. Go to "Settings > Permalinks" and resave the permalink structure.
3. Navigate to "WPML > Support > Troubleshooting".
4. Scroll down and click on the following buttons:
- Clear WPML cache
- Remove ghost entries from translation tables
- Fix element_type collation
- Fix WPML tables collation
- Synchronize local job IDs with ATE jobs
- Synchronize translators and translation managers with ATE
- Set language information
5. Once you've completed these steps, clear the cache from both your site and browser. Then, try to translate a page and see if you're still having the issues.
Let me know how it goes. I'll be happy to help if you need further assistance in this matter.
Best regards.
Prosenjit
October 3, 2024 at 4:52 pm #16251526
alinaM-7
Thanks for your reply Prosenjit,
I went through these troubleshooting steps, but both problems are still happening. Could you take another look? Please let me know if you'd like admin access.
best.
Mary-Jo
October 4, 2024 at 4:11 am #16252298
Prosenjit Barman
Hello Mary-Jo
Thank you for the update.
This type of issue or console error typically occurs when a translation job is initiated on a different domain or configuration than the current one. According to our records, it seems you've migrated your site from "edcapnyorgstg.wpenginepowered.com" to your main domain. It's possible that the translation jobs were started on the staging domain, and now, when attempting to complete them on your main domain, you're experiencing delays.
Could you please make a small update to the default page or create a new page, then try translating it as outlined below and check if the issue persists?
- Please go to WPML -> Translation Management -> Select the page -> Send for translation -> Translate myself -> Go to Translation queue -> Take and translate.
As a side note, I'd like to inform you that we are aware of an issue that occurs when editing translations from the front end. After completing the translation, the page may redirect to a different URL. For more information, please refer to this errata: https://wpml.org/errata/wpml-incomplete-ate-translation-from-front-end-translation-link/
Since you're experiencing a similar issue (being redirected to another page after completing the translation), you can try the workaround mentioned in the errata.
Please let me know the update. I'll be happy to help if you need further assistance in this matter.
Prosenjit
October 4, 2024 at 4:26 pm #16255368
alinaM-7
Thanks Prosenjit.
I created a new test Page as you described. Unfortunately, the ATE gets stuck and I'm still getting the same console error when I translate manually and hit the Complete Translation button. I'm adding a screenshot of what I'm seeing.
I haven't tried the URL redirect solution yet, but this other issue is more critical.
best.
Mary-Jo
October 7, 2024 at 4:05 am #16258870
Prosenjit Barman
Hello There,
I hope you're doing well. Sorry for the delay in responding due to the weekend.
Thank you for trying out the suggestions. As the issue persists, a closer inspection will be required to understand the root cause of the issue.
IMPORTANT
Best Regards,
Prosenjit
The topic ‘[Closed] Delays and redirects when using Advanced Translation Editor / Front-end Review’ is closed to new replies.
