Last updated by Andreas W. 10 months, 2 weeks ago.
April 25, 2025 at 4:07 pm #16969387
pangH
I'm using WPML's Classic Translation Editor on my site hidden link. I'm trying to manage translations effectively, but I'm encountering some issues.
When I remove media images from a post, the old images still appear on the translation page. Additionally, saving a translation job results in a critical error, possibly due to too long data.
How can I ensure that removed media images do not appear on the translation page?
What steps can I take to resolve the critical error when saving a translation job?
April 25, 2025 at 6:02 pm #16969624
To completely remove the media you also need to go to your Media Library, then switch the language inside the top admin bar to any second language, and remove the entries for each language.
Please give this a try and let me know if you run into further issues.
May 7, 2025 at 2:20 am #17004063
pangH
Hi Supoport,
Because we may want to keep the file in media as a backup, but I don't want to show it on the translation page.
Is this work or not?
Best,
Alvin
May 7, 2025 at 3:09 am #17004098
If you make any change to the original content you usually would update the translation using the WPML Translation Editor and after that, you should have the same layout and design in both languages.
If you use the WordPress Editor for creating the translations, then you would need to manually remove the image from the translated content using the WordPress Editor.
May 7, 2025 at 6:59 am #17004549
pangH
Hi Support,
Please refer to my attached images, you can see we only having first image in here, but it still saved before images in translation.
Please check and suggest.
Best,
Alvin
May 7, 2025 at 3:12 pm #17007457
This persists if you complete the translation again to 100%?
If so, I would like to request temporary access (wp-admin and FTP) to the website to investigate the issue further.
IMPORTANT
Video:
The topic ‘[Closed] A few issues we’re facing at WPML’ is closed to new replies.
