Supporter timezone: Europe/Zagreb (GMT+01:00)
Last updated by Dražen 11 months, 4 weeks ago.
Assisted by: Dražen.
March 21, 2025 at 11:51 am
edwinv-4
I am trying to sync ACF WPML fields on my site hidden link.
Some fields are not visible in translation and the sync is stuck.
Why are some ACF WPML fields not visible in translation?
What could cause the sync to be stuck?
March 25, 2025 at 9:14 am #16855581
Dražen
thanks for your patience.
Sometimes sync status can be stuck / needs a long time to sync field status if there are a lot of them. The best is to wait and see if the process is lowering numbers.
I have checked the website, but I see you do not have WPML enabled. Is it okay for me to check further issue on this website or you can provide a staging site where I can safely check? I might need to enable/disable plugins and switch themes.
Also please let me know the page and field that are not showing for translation, so I can check the issue.
Drazen
The topic ‘[Closed] ACF WPML syncing problem’ is closed to new replies.
