Last updated by Dražen 1 year, 10 months ago.
Assisted by: Dražen.
| Author | Posts |
| March 15, 2024 at 9:28 am #15413518 | |
nicolasK-21 |
I recently had a support chat about having the option to set custom prices for variable products with a bulk action like woocommerce has and i wanted to share my solution: You can add code via plugin or in the functions.php file of a child theme to add the functionality in 2 steps. add_action( 'woocommerce_variable_product_bulk_edit_actions', 'set_euro_price_bulk_edit_variation', 10 ); function set_euro_price_bulk_edit_variation() { if ( value !== null ) { if ( value !== null ) { This includes a script to collect the price values via JS prompt. The second step is to add an action to process the data afterwards which is just editing post meta: add_action( 'woocommerce_bulk_edit_variations', 'set_euro_price_bulk_save', 10, 4 ); function set_euro_price_bulk_save( $bulk_action, $data, $product_id, $variations ) { } } |
| March 15, 2024 at 10:22 am #15413809 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, thanks for getting back, I will add this to the related feature request escalated ticket, and any other client in the meantime can try out our suggestion. I was trying to check but there are some errors when you try to add code, I suggest checking this and maybe sharing the correct code, you can use the code button to add it to your text reply. Regards, |
| March 15, 2024 at 12:28 pm #15414257 | |
nicolasK-21 |
Hi, |
| March 15, 2024 at 1:40 pm #15414651 | |
Dražen Supporter
Hello, you can wrap it in code tags or just share Pastebin link and I will edit your reply and add it inside so other users can use it if needed. - hidden link Regards, |
| March 15, 2024 at 2:06 pm #15414750 | |
nicolasK-21 |
All right, here's the code i use: <?php
/* Add the Dropdown options to the product editor: */
<optgroup label="Euro price">
<option value="set_regular_euro_price">set regular price</option>
<option value="set_sale_euro_price">set sale price</option>
</optgroup>
<script>
jQuery( function(){
jQuery( 'select.variation_actions' ).on( 'set_regular_euro_price_ajax_data', function(e, data) {
var value = window.prompt( "set regular price" );
data.value = value;
return data;
} else {
return;
jQuery( 'select.variation_actions' ).on( 'set_sale_euro_price_ajax_data', function(e, data) {
var value = window.prompt( "set sale price" );
data.value = value;
return data;
} else {
return;
</script>
<?php
/* Processing the data added through the bulk action */
if( in_array( $bulk_action, [ 'set_regular_euro_price' ] ) ) {
if( isset( $data['value'] ) ) {
foreach( $variations as $variation_id ) {
// Update post meta will not update if variation_id exists, thus no check is necessary
// Else use if ( $variation = wc_get_product( $variation_id ) )
update_post_meta( $variation_id, '_regular_price_EUR', esc_attr( $data['value'] ) );
update_post_meta( $variation_id, '_price_EUR', esc_attr( $data['value'] ) );
update_post_meta( $variation_id, '_wcml_custom_prices_status', '1' );
if( in_array( $bulk_action, [ 'set_sale_euro_price' ] ) ) {
update_post_meta( $variation_id, '_sale_price_EUR', esc_attr( $data['value'] ) );
| March 15, 2024 at 2:25 pm #15414790 | |
Dražen Supporter
Hello, great, thanks for sharing. Your feature request is escalated, and we will consider it for future version development. I can not guarantee that this will be accepted and implemented and when. Thanks for reporting and suggesting this. Regards, |
