The client needs a responsive menu plugin that works without the 'Adjust IDs for multilingual functionality' option enabled, as it affects performance. The client's current plugin, Max Mega Menu, requires this option, and another suggested plugin, Responsive Menu, also needs it according to its manual.
We recommend testing the following WPML-compatible responsive menu plugins in your setup to see if they can operate without the 'Adjust IDs for multilingual functionality' option:
If these options do not resolve your issue, or if the information provided becomes outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still encounter difficulties, please open a new support ticket at WPML support forum.
Last updated by Andrey 2 weeks ago.
Assisted by: Andrey.
February 23, 2026 at 7:24 pm #17844240
dmitrijsH
In you support forums, you say that for performance, I need to disable "Adjust IDs for multilingual functionality". However, the menu plugin I use (Max Mega Menu) needs it.
I checked for other responsive plugins. You say that Responsive Menu is fully compatible: https://wpml.org/plugin/responsive-menu-2/
However, it also needs that option on, according to their manual: hidden link
Is it possible to turn off this option and find a responsive menu plugin that would work?
Kind regards,
February 23, 2026 at 8:01 pm #17844316
Andrey
WPML Supporter since 06/2013
I’m afraid I’m not able to recommend a specific responsive menu plugin that will work with the “Adjust IDs for multilingual functionality” option disabled. You would need to test it in your setup to confirm this.
However, here are three menu plugins that are officially compatible with WPML:
• Responsive Menu
• UberMenu
https://wpml.org/plugin/ubermenu-3/
• Mega Main Menu
https://wpml.org/plugin/mega-main-menu/
