After migrating the site from a local environment, the Advanced Translation Editor (ATE) is stuck. The 'Save and complete' action does not finish, and translation jobs remain in progress. The ATE account appears to still be linked to the old local/staging site ID.
We recommend trying the following steps:
1. Clear all caches, including browser, plugin, and server-level caches if applicable.
2. Increase the PHP memory limit to at least 256M or 512M.
3. Update your PHP version to a recent supported version, such as 8.1 or 8.2.
If these steps do not resolve the issue, the solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by gavinS-4 2 months, 1 week ago.
Assisted by: Andrey.
February 16, 2026 at 10:26 pm #17827056
gavinS-4
Hello WPML support,
After migrating my site from a local environment to
the Advanced Translation Editor is stuck:
“Save and complete” does not finish
Translation jobs remain in progress
No PHP or REST errors
Live site translations still work correctly
Troubleshooting actions and job synchronisation were already performed
It seems the ATE account is still linked to the old local/staging site ID.
Could you please reset the ATE account connection for this site?
Site key is already registered correctly.
Thank you in advance.
February 16, 2026 at 11:34 pm #17827119
Andrey
WPML Supporter since 06/2013
I want to confirm if you have tied the following step?
1. Go to Plugins → Add New and click the Commercial tab. Click Unregister WPML from this site.
2. Once the page loads, click on Register WPML. A message asking you to enter the site key will appear. Click on Get a key for this site.
3. In your WPML account, complete the site key wizard and set it to Production site.
4. Copy your new key and paste it in the Commercial tab.
February 17, 2026 at 3:57 pm #17829740
gavinS-4
Thank you for your reply.
I followed the unregister/register steps again, but the issue remains.
In the Advanced Translation Editor:
- Segments are marked as “concept”
- I cannot edit or confirm the segments (no pencil or check icons available)
- “Save and complete” stays blocked
- This started after migration from the local site
- Live site translations work normally
This looks like a broken or locked ATE translation job linked to the old site ID.
Could you please reset the ATE jobs or the ATE account connection server-side?
I have attached a screenshot showing the locked segments.
February 17, 2026 at 4:32 pm #17829964
Andrey
Thank you for your feedback.
February 18, 2026 at 6:17 am #17830802
gavinS-4
"Sorry, I forgot the FTP details. If you still need them, please send me the form again and I will fill in the information."
February 18, 2026 at 10:19 am #17831640
Andrey
Thank you for the details. I will look into it and let you know as soon as I have more information.
February 18, 2026 at 10:42 am #17831750
Andrey
I’ve looked into this on my side, but I’m not able to reproduce the issue.
I opened the same page, launched the Advanced Translation Editor, saved the segments, and completed the translation without any problems. Everything appears to be working correctly in my tests.
I also want to mention that I was able to edit the segments, and if you move to another one, the previous one gets autosaved.
Could you please clarify what step I might be missing?
In the meantime, I recommend trying the following:
• Clear all caches (browser, plugin, and server-level cache if applicable).
• Increase the PHP memory limit (for example to 256M or 512M).
• Update your PHP version to a recent supported version (e.g. 8.1 or 8.2).
I’ve attached screenshots for your reference showing the steps I followed and the successful result.
February 18, 2026 at 5:05 pm #17833440
gavinS-4
Thank you very much for your help and for taking the time to investigate this issue.
It turned out that the PHP memory limit was the cause of the problem. After increasing the memory limit, the Advanced Translation Editor started working correctly again. This was something I had completely overlooked, so your guidance was very helpful.
Unfortunately, I cannot increase the PHP version for the current live website because it would stop working. That is why we are now building a new website in a separate environment.
I really appreciate your support and quick assistance.
Kind regards,
Gavin
