This topic contains 12 replies, has 0 voices.
Last updated by Otto 4 months, 2 weeks ago.
Assisted by: Otto.
| Author | Posts |
| November 26, 2025 at 12:16 pm #17611576 | |
gertV-7 |
| November 26, 2025 at 3:21 pm #17612730 | |
Otto |
Hello, I tried to reproduce the issue from scratch, but it worked for me: You can check the site's backend by following this link: Can you please try to reproduce the problem there? Maybe I am using another element or not following the right steps to see the problem. Thanks! Best Regards, |
| November 28, 2025 at 10:05 am #17617725 | |
gertV-7 |
Hi and thanks, I am not sure how to reproduce it but it probably has to do with automatic translation. |
| November 28, 2025 at 2:15 pm #17618360 | |
Otto |
Hello, Thanks. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. The information you will enter is private which means only you and I can see and have access to it. **IMPORTANT** Best Regards, |
| December 1, 2025 at 8:33 am #17621590 | |
gertV-7 |
Hi, You can use this link for login. There is already a duplicator plugin installed but feel free to try the other one you suggested. Kind regards |
| December 1, 2025 at 2:06 pm #17622824 | |
Otto |
Hello, Thanks. This is really weird 🤔. I am not able to make it work. Before escalating the problem to our second tier support, can you please update Elementor and Elementor pro to their latest versions and check if the issue persists? ❌ Please make a full website backup before proceeding ❌ Best Regards, |
| December 2, 2025 at 1:27 pm #17626534 | |
gertV-7 |
Hi, I updated Elementor and Elementor Pro but the issue is still there. On the homepage everywhere where there needs to be B&B it show just "B". Thanks for asking this to the second tier support. Kind regards, |
| December 2, 2025 at 3:21 pm #17627311 | |
Otto |
Hello, Thanks. I've escalated the issue to our second tier support. I'll get back to you as soon as I have a reply. Meanwhile, you can try the following workaround: Best Regards, |
| December 2, 2025 at 8:14 pm #17628395 | |
Otto |
Hello, The problem may be due to the translation memory. I've tried the following locally, and it worked, can you please give it a try? ❌ Please make a full website backup before proceeding ❌ - Make a small change in the original language Is this a suitable workaround for you? Best Regards, |
| December 3, 2025 at 12:17 pm #17630642 | |
gertV-7 |
Hi, I tried this but it didnt work. i changed it to A&A but then it shows AA Oase. Kind regards, |
| December 3, 2025 at 2:49 pm #17631312 | |
Otto |
Hello Robin, Thanks. I'll get back to you as soon as I get a reply from our second tier support. Best Regards, |
| December 9, 2025 at 12:16 pm #17647430 | |
Otto |
Hello, We modified an ATE setting on our end. Can you please give it another try and let us know if the issue is solved? Please test it following these steps: Use a new string with the ampersand, like D&D. Let us know how it goes, please. Thanks! Best Regards, |
| December 12, 2025 at 2:37 pm #17659638 | |
gertV-7 |
Hi, I tried this and it works now, thank you! Kind regards, |
| December 12, 2025 at 2:45 pm #17659673 | |
Otto |
Hello, Great, I am happy to hear that 🙂 Have a great weekend. Best Regards, |
