Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 1 year, 9 months ago.
Assisted by: Bobby.
May 13, 2024 at 11:06 pm #15622678
mustafaK-15
Hello. I created custom post type (product) and, custom taxonomy (product-category) with ACF plugin.
I created taxonomy-product-category.php to loop product posts. And listed with default while query (check attachment).
But i have a weird problem. When i navigate page 5 or next pages, product posts appear randomly. They look as if the orderby value is rand.
Interestingly, it only happens on pages 5 and up.
Check page 4. Its all good. hidden link
But check page 5, hidden link
Posts appear randomly.
I deactivated all plugins (except wpml plugins) and tried with default theme. Same results.
If i deactivate wpml plugins also, all posts (including translated posts) are appearing in normal order.
May 14, 2024 at 8:42 pm #15627066
Bobby
WPML Supporter since 04/2015
Timezone: America/Los_Angeles (GMT-08:00)
I have browsed between pages 4 and 5, to verify, when I am on page 5 I can see that now I am starting to see some posts that are not titled as "classic", is this the issue?
Monesa Gold Leaf Bedroom for example.
if you review this product as an example in the backend does it happen to be categorized as 'classic bedroom' ?
May 16, 2024 at 12:03 pm #15634877
mustafaK-15
Hello, thank you for yor reply. It is not about titles. Also there is no problem on categories.
Check the results of page 5, you will see different products every page refresh.
Check this please: hidden link
May 16, 2024 at 10:30 pm #15637229
Bobby
Thank you for the screencast I can see the issue now!
I created a sandbox environment to attempt to reproduce the behavior but could not do so.
How are you adding the pagination to the blog? Is this done using custom code?
Sandbox with default WP pagination
Login: hidden link
May 17, 2024 at 8:14 am #15637934
mustafaK-15
No it is default WordPress pagination with default query. Check the attachment.
I disabled infinity scroll to see pagination. You can see now.
Btw, your sandbox site doesn't have any problem. I am trying to find what is the problem on my side.
May 17, 2024 at 4:22 pm #15640499
Bobby
Thank you, the goal of the sandbox is to try and reproduce the behavior in a clean environment.
If WPML has a bug in its code then it is fairly easy to reproduce in a clean environment.
Thank you,
Bobby
The topic ‘[Closed] Archive posts appear randomly’ is closed to new replies.
