When WPML plugins are active, the client cannot access the Astra Pro customize page. Errors occur, including a PHP notice about an incorrectly called function and a fatal error due to memory exhaustion.
We recommend increasing the PHP memory limit to 512M to handle the operations with the number of plugins installed. This adjustment can be made by editing the wp-config.php file and adding or updating the following line:
define('WP_MEMORY_LIMIT', '512M');
Ensure this line is added before:
/* That's all, stop editing! Happy publishing. */
For detailed instructions, visit Increasing memory allocated to PHP.
After making these changes, please test the functionality again.
If this solution does not resolve the issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
Last updated by Andrey 2 months, 4 weeks ago.
Assisted by: Andrey.
February 14, 2026 at 6:49 pm #17822780
thomasK-90
When WPML plugins are active, I cannot access astra pro customize page.
February 14, 2026 at 8:37 pm #17822886
Andrey
WPML Supporter since 06/2013
To better understand your situation, could you please enable debugging, replicate the issue, and share the full error message from your debug.log file?
Here are the steps:
1. Enable WordPress debugging by editing your wp-config.php file. Add (or modify, if these lines already exist) the following lines before the comment /* That's all, stop editing! Happy publishing. */:
define( 'WP_DEBUG', true );
2. Replicate the error.
3. Check the debug.log file (located in the /wp-content/debug.log) for any WPML-related errors.
4. Copy and paste the full error message here.
February 16, 2026 at 6:20 am #17824256
thomasK-90
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 6976328 bytes) in /public_html/wp-includes/script-loader.php on line 3015
February 16, 2026 at 1:11 pm #17825802
Andrey
Thank you for your feedback.
It looks like your current PHP memory limit is set to 128M, which may not be sufficient for the operation you’re performing with the number of plugins installed. I recommend increasing it to 512M, and then testing the issue again.
You can increase the WordPress memory limit by editing your wp-config.php file and adding (or updating) the following line:
define( 'WP_MEMORY_LIMIT', '512M' );
Make sure this line is added before the line:
You can find detailed instructions in the official WordPress documentation:
https://developer.wordpress.org/advanced-administration/wordpress/wp-config/#increasing-memory-allocated-to-php
After increasing the limit, please test again and let me know the results.
February 16, 2026 at 1:29 pm #17825852
thomasK-90
Still error coming after adding the line.
[16-Feb-2026 13:27:59 UTC] PHP Notice: Function WP_Scripts::add was called incorrectly. The script with the handle "awf" was enqueued with dependencies that are not registered: jquery-blockui. Please see Debugging in WordPress for more information. (This message was added in version 6.9.1.) in /public_html/wp-includes/functions.php on line 6131
[16-Feb-2026 13:28:03 UTC] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 6976328 bytes) in /public_html/wp-includes/script-loader.php on line 3015
[16-Feb-2026 13:28:06 UTC] PHP Notice: Function WP_Scripts::add was called incorrectly. The script with the handle "awf" was enqueued with dependencies that are not registered: jquery-blockui. Please see Debugging in WordPress for more information. (This message was added in version 6.9.1.) in /public_html/wp-includes/functions.php on line 6131
February 16, 2026 at 1:35 pm #17825887
Andrey
Did you actually increase the PHP memory limit? You might need to contact your hosting provider if the value is not yet increased or follow the documentation I shared earlier.
Please upload a screenshot of WPML → Support and the Info PHP section.
February 16, 2026 at 1:47 pm #17825931
thomasK-90
I changed on my cloudways server setting the memory limit to 512mb. But still not working.
February 16, 2026 at 1:50 pm #17825935
Andrey
Please provide the steps to replicate the issue on your site.
February 16, 2026 at 1:57 pm #17825973
thomasK-90
There were some other setting I could do for memory limit increase on Cloudways. Now it is working. Thanks!
February 16, 2026 at 2:19 pm #17826039
Andrey
Great! Thanks for letting me know.
Have a nice week!
