The client's WooCommerce site, set to 'Translate all' and 'Publish without revision,' was not automatically updating product translations after changes in the original language. Products updated by a third-party application were queued with 'Waiting for translator' status, and attempts to manually update translations resulted in an 'ateJobCreationError=101' error.
We recommended ensuring that the WPML settings were configured correctly: 'Publish without review' should be enabled, and the Advanced Translation Editor set as the default. We also advised checking that 'pay as you go' was activated with sufficient credits. For the specific error 'ateJobCreationError=101', which indicated issues with the XLIFF files not belonging to the system, we suggested checking the ATE error logs for more details. If the problem persisted, we recommended manually making a small change to the affected products and updating them, which could help restart the automatic translation process. Additionally, disabling 'Translate Everything Automatically' temporarily could help manage and resolve stuck translation jobs in the WPML > Translation Management page.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket for further assistance at WPML support forum.
| Author | Posts |
| March 12, 2025 at 2:33 pm #16807701 | |
nicolasL-34 |
| March 12, 2025 at 3:25 pm #16808060 | |
nicolasL-34 |
Additional Information: |
| March 12, 2025 at 9:51 pm #16809293 | |
Bobby WPML Supporter since 04/2015
Languages: English (English ) Timezone: America/Los_Angeles (GMT-07:00) |
Hi there, Please go to WPML->Settings-> What would you like to do after WPML finishes translating your content automatically? set to "Publish without review " Translation Editor -> set it to Advanced Translation Editor. (From your screenshots it looks set up OK) Next step is to confirm that the site has 'pay as you go enabled' and that there are enough credits. Go to WPML->Translation Management->Tools and verify that pay as you go is activated and there are no errors there. Sometimes a pause to the translation can happen if you hit a limit and an invoice is waiting to be cleared. Let me know your results! |
| March 13, 2025 at 8:21 am #16810378 | |
nicolasL-34 |
Hi, |
| March 13, 2025 at 10:26 pm #16813925 | |
Thank you for the screenshots! For this page and job ID hidden link I located the translation into PT but I see that it was finished in 2024 which confirms what you are describing if new changes were done to this page lately. Please go to WPML->Support->ATE Error logs and share with me the top 5 errors logged there. In the backend from our side I am not seeing something that stands out at the moment, these logs should help. |
| March 14, 2025 at 6:58 am #16814633 | |
nicolasL-34 |
Hi, Thanks for your response, here are the last 5 logs in the ATE errors logs, all others logs have the same event "XLIFF Server Communication", the same description "The uploaded xliff file doesn't belong to this system." and the same WPML Job ID and ATE Job ID. The last log I see is from 2025/03/13 1:34:57 PM : 2025/03/14 6:50:13 AM XLIFF Server Communication The uploaded xliff file doesn't belong to this system. 18035 130550924 {"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/092\/570\/668\/original\/translated_129286197_50_pots_ronds_kraft_500_ml20250224-15585-19klc8s.xliff20250224-13575-abd3af.xliff?Expires=1742539811&Signature=eYqC7vekaNEr8WpnpPocOQ3FC0nhXBm~8R9OuukUqOLfeY~zzmeKad7igoOmHSWN1S5ptTbeDF3I1i3yIfs1VMsAJwGOu-JSTeI8arwA3~Ku9xqH1ThEjyY42j887ES~-kCkm4th3xN7OWQyxma0cn6MvwRz0BGEkhO5JTrQFaBVKBLaZsCCvRqn1PKvvTsg5GW9jJLtr9wQWMCXiLjeitYJIgp2FeyJCUcSfwtxz78riO4Ee5ifuc6qZiDRtcVwsLtFkHNxBZD2etvdn5~AISkZFgDxXF6pf5J~9A5NglqCI1N6vnsejiQGLCOIfizRcOobPPbPi4Qo~HL2DIhYrg__&Key-Pair-Id=K1C11UVRQNXLRQ"} 2025/03/13 4:39:41 PM XLIFF Server Communication The uploaded xliff file doesn't belong to this system. 18035 130550924 {"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/092\/570\/668\/original\/translated_129286197_50_pots_ronds_kraft_500_ml20250224-15585-19klc8s.xliff20250224-13575-abd3af.xliff?Expires=1742488778&Signature=YN-JSxLflTHoFZ6-QUlhIMoS2R7qDNCh7SiKJ~apcYkZ4abYcpWqObDQyXv8Sxcrp1qnBmKx5FKATGZ3ZOGllgzr95bgZH90mgzqF5D44oj5VfnZqyXqQRxMAmLb0GV1WYOhEKH59fWv8muRzYhlmYyCE7hLiJpnWw5tYDwY9Z6amTmOytKac-BLkwlCv16WVu6mvkse5o8pGLFVPKTYK6BgMKhFKGVKyl-OqlIL~Z~o0S~byfL7TkLS78QubL8dC2PUFOQ5U0S3rbnuAA9uwoqZyJR7SQ5docvlFtgPjV4PNW4xW7C0q2~s-o~mfx0RJiZeH14ep8lCxIGWhs6u6g__&Key-Pair-Id=K1C11UVRQNXLRQ"} 2025/03/13 4:38:51 PM XLIFF Server Communication Le fichier xliff transféré n'appartient pas à ce système. 18035 130550924 {"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/092\/570\/668\/original\/translated_129286197_50_pots_ronds_kraft_500_ml20250224-15585-19klc8s.xliff20250224-13575-abd3af.xliff?Expires=1742488729&Signature=vDieU-uzRAnd4Cip~PpBJxhfZWHB6kfXVqzoOpEI7BgvQ8j15U9IyfqLYypLItknGz8xd-xYx3Bs26ijaKxmXBo18oE4fE45KaAs6-DTDaw0wdHGrd8zcO-F3iDFMI-QAcwrZ3XhkVF1kBDtFOrHUsEvnYqSXVur-U0QkVJSESmLhg9HnpZVjF428oKLargCeP~D7xKGJ9dRPt00HYLOgoJ2jHdkBmycPTVVnus~HzAo0eBAJPWDvofP-IKXyHV5v3u8ZRl42RBmgvsL0W8vMfVk5X5BIlR3sAQgKa4Gze71Mj6CqCzE~-TVSdbx4slTjj5DoCeuhlsGhOI7IshTMw__&Key-Pair-Id=K1C11UVRQNXLRQ"} 2025/03/13 3:57:51 PM XLIFF Server Communication The uploaded xliff file doesn't belong to this system. 18035 130550924 {"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/092\/570\/668\/original\/translated_129286197_50_pots_ronds_kraft_500_ml20250224-15585-19klc8s.xliff20250224-13575-abd3af.xliff?Expires=1742486269&Signature=uu9kfsdl3SXexkMIZZqbOklDM9ENSOLNZW-RqGEC9Wve7Z2kc0dRjXCchSlJL-0FkVnN252orQBfm3JOoWhmQmOh6o~XbIcUvSBXq8keDp9bJCFXKytVDZa9f9wowxhJC9QG9ZlBRFiJycXrp1FyVNM7zZtooxXlNurrq9Y4HgpYjjmsXAkf45olhIsW-mZbzBN86nyHA1iu8qqOFAGzemBaSWZC3136nZ9ndOfZsJmHsL5E1u1h41ZYy--3zTqUs0NcrXMnyqOId-x12ElCZhWYYyayghz9ZB-jgDNdL-~O9dSzqM2mZImybJZwqPovh5w~p-MwAena1TvlUfm6fw__&Key-Pair-Id=K1C11UVRQNXLRQ"} 2025/03/13 3:56:47 PM XLIFF Server Communication The uploaded xliff file doesn't belong to this system. 18035 130550924 {"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/092\/570\/668\/original\/translated_129286197_50_pots_ronds_kraft_500_ml20250224-15585-19klc8s.xliff20250224-13575-abd3af.xliff?Expires=1742486204&Signature=lATCEVs0KarGeiOzYN5zFR5TxndWyePgQjazF5-WgV~gfPgNkGLL2FteVU2wQ5rObwZtS65Qclh61ztTv-IQ~buI-a2NUPCUQSIBvQSLWf7zYHnzis1DpZRvFMQXQq6gzMxQqWbrA2nlgY~FAbXzaL9Mmam--MuKPEagknVUlB8LKewl-1wjvJoDw0AyJ30Z6C-jVa94DBYO8stUDBuFBoe~S0zL9kkUMsGi2iIKLU~V9oA3WIuqfOc0Za8pMZ0~GAWM3sSUXvyOjW~TN~PUC2dIN74EcIjpxoDi-nfdLrrUjWXhf3a3ASyB97hTfvTtBCzMz-Qd2Ob007AMiKTY8w__&Key-Pair-Id=K1C11UVRQNXLRQ"} |
| March 14, 2025 at 10:30 pm #16818779 | |
I would like to request temporary access (wp-admin and FTP) to your site to test the issue. **Before we proceed It is necessary to take FULL BACKUP of your database and your website. Providing us with access, you agree that a backup has been taken ** I often use the Duplicator plugin for this purpose: http://wordpress.org/plugins/duplicator/ NOTE: If access to the live site is not possible and the staging site does not exist please provide me with a duplicator package created with the duplicator plugin. Thank you, |
| March 20, 2025 at 8:12 pm #16841835 | |
Thank you for the access details! This specific issue is most likely related to your ATE account with WPML and it's communication with your site. Is it possible to provide me access to the live site? I will not be making any changes, just need to review the behavior after sending the page to translation and the errors logged. The current staging site looks configured well but the AMS account is not the same and the set of errors are separate. |
| March 21, 2025 at 9:10 pm #16846478 | |
Thank you for the access details! Please try to translate a product and let me know your results now. Also, share with me the product you are testing with so I can also test it. |
| March 24, 2025 at 2:11 pm #16852561 | |
nicolasL-34 |
Hi, I just send this product for translation : But my problem isn't really the translation of the products when I send them manually, but the fact that they aren't translated automatically. I have to go to the admin each time to launch the translations, even though I want everything to run automatically. Thanks, |
| March 24, 2025 at 8:56 pm #16853999 | |
Thank you, I ran a test on this product and the automatic translation worked as expected. Added a new word to the description -> updated the FR product hidden link |
| March 26, 2025 at 3:10 pm #16863675 | |
nicolasL-34 |
Hi, I don't understand why all these products translations aren't automatically update. |
| March 26, 2025 at 11:24 pm #16865786 | |
I can see that 147 translations remaining in the queue... as of right now Also, If I review the product I can see that they are tranlating as expected. There are however a good amount of products in the "translation needs update" status, my theory is that these were stuck in this state before the automatic translation was activated. Please try submitting them via Translation Management by bulk for translation. You can filter and then bulk select them either (bottom of the page you can increase from 25 to more items, I suggest staying under 100 to prevent server load) However, I can't reproduce this behavior with a new page, if I make changes the changes get applied automatically |
| March 27, 2025 at 3:34 pm #16869430 | |
nicolasL-34 |
Hello, |
| March 27, 2025 at 7:29 pm #16870311 | |
Thank you for updating me! I have been in communication with Agnes after your discussion and she filled me in. The issue is escalated to our team and we are taking a closer look to make sure it resolves. I also verified the issue using the page you provided above and was able to resolve it by manually doing the following. 1. small edit to the product and update Of course we are reviewing this and will provide additional information once I have more feedback. |
