Last updated by Andreas W. 1 year, 11 months ago.
May 17, 2024 at 12:45 pm #15639726
kurtA-8
I use for my websites auto translation.
I want to write a plugin that adds variable products or single products to woocommerce.
i use the function new WC_Product_Variable() or WC_Product_Simple(); if i use this function and a product is created is the translation also automaticly done?
Thanks in advance.
May 17, 2024 at 7:50 pm #15640917
If you call the "save_post()" function in your code, then it usually should trigger the automatic translation, if "Translate everything automatically" is used as translation mode.
I can offer a WPML test site with a fake translation engine for testing if you would like to give it a try.
Let me know and I will send you a link.
The topic ‘[Closed] auto translation for code generated woocoommerce product’ is closed to new replies.
