Last updated by Bruno Kos 2 months, 1 week ago.
Assisted by: Bruno Kos.
February 11, 2026 at 9:24 am
simonL-80
I am trying to translate Beaver Builder Saved Rows, Templates, Module and components. I have followed the solution described here:
https://wpml.org/forums/topic/auto-translation-is-not-working-for-the-beaver-builder-saved-rows-column-template-and-module/
Unfortunately, when I try to re-select the translated saved row as suggested in step 4.B, loading the translated version in beaver builder does not work and freezes (see attached).
Could you kindly support in identifying the cause of and solving this issue?
Thank you
February 11, 2026 at 12:34 pm #17812760
Bruno Kos
On this sandbox, can you do this:
- create a very simple row/column or module with some simple text element
- translate it
- add it to the page and translate the page
Does the translated row/column/template shows the translation? This is the workflow that is expected to work, correct?
Let me know if you have any questions!
February 14, 2026 at 2:09 pm #17822578
simonL-80
Sorry for the late reply, I had not seen your update
The workflow should be:
- create a beaver builder template / rows / modules. In this case, I use the "Test EN" component you have created
- create a page. In this case, "Sample page - simple"
- Edit the page in beaver builder, import the component and modify its attribute. In this case, I import the "Test EN" component and modify the associated text.
- Translate the page
In this case, the issue remains, and the text associated to the "Text EN" component on the "Sample page - simple" does not appear in the advanced translation editor
I would like to be able to translate it and ideally to appear there.
Thank you
February 16, 2026 at 8:33 am #17824611
Bruno Kos
I see there are few Modules here:
There were not translated so I translated them.
However I don't see any of these applied on hidden link, have you added them here or into some other page?
The topic ‘[Closed] Auto Translation is not Working for the Beaver Builder Saved Rows, Column, Template and Module’ is closed to new replies.
