You are experiencing a slowdown in the automatic translation process of over 100,000 products using WPML, with the translation queue initially growing quickly but then slowing significantly.
We recommend manually sending products in batches for automatic translation to manage the workload more effectively. Additionally, in the upcoming WPML 4.7 release, we will introduce additional filters in the Translation Management tool. These filters will allow you to filter products by category, enabling you to translate one product category at a time more efficiently.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
This topic contains 0 reply, has 2 voices.
Last updated by Marcel 1 year, 4 months ago.
Assisted by: Marcel.
| Author | Posts |
| October 28, 2024 at 9:08 am #16336508 | |
g.v |
| October 28, 2024 at 10:58 am #16337273 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Vienna (GMT+02:00) |
Hi, my name is Marcel and I will take over your ticket. Could you please provide me with site access for further testing? I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” or "All in One WP Migration" on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you. IMPORTANT Best Regards, |
| October 28, 2024 at 1:41 pm #16337898 | |
g.v |
Dear Marcel / WPML, I am currently creating a backup and don't yet see the input fields for FTP and WordPress access. I assume these fields will appear once I send this message to start the chat. If that’s not the case, could you please make these fields visible or enable the private box? Kind regards |
| October 28, 2024 at 2:01 pm #16338057 | |
g.v |
Dear Marcel / WPML, I can create an admin account for WordPress access. Do you have a preferred email address, or should I use one of our own? I still can't see the input fields for FTP and WordPress access, even when I click the button in the email. Could you enable the private box? Kind regards |
| October 28, 2024 at 2:19 pm #16338118 | |
Marcel Supporter
Hi, The input fields will appear once you accept the disclaimer and backup. You can use a placeholder email like noreply@wpml.org, as this address should be added to the secure fields to prevent any actual email from being sent. Best regards, |
| October 28, 2024 at 3:43 pm #16338650 | |
Marcel Supporter
Hi, In this case, it would be best if you create a copy of the site using WP Staging Pro so we can test it first on the cloned version. Please note that I won’t be installing any plugins on your live site. Since there's no need to go through any order processes, disabling outgoing emails shouldn't be necessary. We'll work directly on the clone, isolating this issue first and reviewing the debug.log. Best regards, |
| October 30, 2024 at 5:02 pm #16348635 | |
Marcel Supporter
Thank you! I’m currently in touch with our Translation Editor developers, and I’ll keep you updated as soon as we have a solution. Best regards, |
| November 4, 2024 at 2:43 pm #16361721 | |
Marcel Supporter
Hi, We’re still investigating this issue. The logs initially show a gateway error, followed by re-queued jobs being sent to our editor. This points to a potential server communication issue, but we’ll also review the editor logs for further insights. Best regards, |
| November 7, 2024 at 8:01 am #16375486 | |
g.v |
Dear Marcel, Good to hear you’re still investigating the issue. Here’s a quick status update: on the first day, the automatic translation added around 10k items to the translation queue; by the end of the first week, the total reached about 15k items, and now, two weeks into the automatic translation process, we’re at 35k items total. Its a little bit of a problem, because at the current rate the translation queue will still take over 5 weeks to complete. If there’s anything we can do to help, feel free to ask. Regarding the staging website information we shared: the WPML settings for translation are still set to ‘Different domain,’ but it may be useful, when testing, to switch to ‘Different language in different folders.’ Kind regards |
| November 7, 2024 at 10:40 am #16376379 | |
Marcel Supporter
Hi, Thank you for the information. As mentioned previously, we suspect a server-side issue, as the REST-API request seems to be blocked. Could you please provide us with a duplicator copy of the production site? This will allow us to test it in a different hosting environment and confirm if the server is contributing to the interference. Thank you! Best regards, |
| November 11, 2024 at 10:07 am #16387742 | |
g.v |
Dear Marcel, I made a copy using Duplicator and would like to share the file via Google Drive. However, I don’t want to make the link publicly accessible. Do you have an email address I can use to share the folder with you? Kind regards |
| November 11, 2024 at 12:09 pm #16388403 | |
Marcel Supporter
Hi, I’ve activated a private input field for you to share the download link. Best regards, |
| November 14, 2024 at 11:06 am #16401902 | |
g.v |
Dear Marcel, I am hesitant to send the Google Drive link due to security reasons, as the link would be publicly accessible. Before I send it, I have a question. The automatic translation process seems to be slowing down. Is there a way to limit the automatic translation to just one category? If we could divide the 100k products into smaller groups, such as 10k products per group, perhaps the automatic translation process would be faster. If there is another way to limit the automatic translation, could you please share that with us, or provide some code that could accomplish this? If this option isn't possible, we will consider sharing the link instead. Kind regards |
| November 14, 2024 at 4:17 pm #16404068 | |
Marcel Supporter
Hi, as mentioned earlier, the private reply field is activated, so the link will be shared privately.
Limiting the translation would not resolve the issue if the REST-API request remains blocked. We need to investigate whether your server is causing the request to be blocked. Testing in a local server environment could help us identify the cause. Best Regards, |
| November 18, 2024 at 5:10 pm #16416098 | |
Marcel Supporter
Thank you! I've successfully downloaded the file. I will let you know once I find something. Best regards, |
