The client reported an issue with WPML where they were charged $170 for automatic translations of already translated products. The client also experienced random changes in the admin language and issues with taxonomy translations not being considered in credit calculations.
We investigated the issue and identified it as a bug unrelated to Automatic Translation Editor (ATE). As a temporary workaround, we recommended the client to uncheck the 'Don't show translated taxonomies in Translation Editor' option in WPML > Settings. For the overcharged credits, we offered a refund of 10,000,000 credits to the client's WPML.org account. Additionally, we escalated the bug for a permanent fix in future WPML versions. For further issues, we opened separate support tickets to address them specifically.
If this solution does not resolve your issue or seems outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at https://wpml.org/forums/.
Last updated by Dražen 2 months, 2 weeks ago.
Assisted by: Dražen.
| Author | Posts |
| April 1, 2025 at 7:05 pm #16884362 | |
nicolasF-24 |
Background of the issue: Firstly, can you please identify this bug ? and how can i get my monney back ? Because 170 dollars for already almost fully already translated products it's not normal ... Thanks for your help Symptoms: Questions: |
| April 2, 2025 at 8:56 am #16885966 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, Thanks for contacting us. I have checked and I can see that for this hidden link, it is charged 392 credits. Can you share more info, date and ATE Job ID / URL where you see you are charged again for same translation? And maybe month / date of the original job where you translate this. I also see you moved your website on March 06. Did you maybe select not to share translation memory from previous website / instance? Let me know and I will check further. Thanks, |
| April 2, 2025 at 9:14 am #16886067 | |
nicolasF-24 |
Hi Drazen, In think that it's the same problem as last time, and that there is truly a problem No I didn't remove the memory and I still have it + the glossary (I think) I made the translation yesterday, you can download the report you will see the product inside And now I see that the description is in spanish for French, whereas it's well in French for the category I don't understand why WPML is putting that in a different language, and I understand so why it ask me to translate it again |
| April 2, 2025 at 9:25 am #16886082 | |
nicolasF-24 |
And indeed it translated it in Spanish so for English language for example : |
| April 2, 2025 at 9:58 am #16886324 | |
nicolasF-24 |
On your calculations, you don't consider taxonomy translations ... |
| April 2, 2025 at 10:14 am #16886409 | |
nicolasF-24 |
Again, it takes me now Italian, instead of French, and I have ready 100 usd for nothing ... It's never in Italian I don't know where Wpml goes search this Please can you see quickly for the credit, i'am already at 300 for two days for almost no 20 REAL translations .... |
| April 2, 2025 at 11:50 am #16886732 | |
nicolasF-24 |
Can I erase all the pending existing translations, everything is wrong, and WPML translate wrong almost all my categories, now I have to pay again to make them in the true language, I'm really disappointed |
| April 2, 2025 at 1:32 pm #16887325 | |
Dražen Supporter
Hello, First, I would advise disabling automatic translation from WPML > Translation Management, and from WPML ATE editor, there is a top right cog/settings icon, click and disable automatic translation. That way you will not be charged for any more of translation. Then please share with me you wp-admin of website, and example of product URL, where this happens, and I will try to have a look and see what might be causing this issue with category description not being in correct language. Regards, |
| April 3, 2025 at 6:14 am #16889831 | |
Dražen Supporter
Hello, thanks. I checked hidden link, but I do not see issue with the category text in the wrong language. 1) What I can see is that at some point, you changed the category assigned from Tablero de equilibria > Balance board. When you did that, you where not charged again for the translation of this description since it was already translated before and loaded from your memory. As for those description that where charged, I think this is probably the same issue as it was in our last ticket, where category description changed and you where charged for this new translation, since segment can not be find in translation memory, they need to be exact the same, same space etc. So you probably still have left some category description to translate. If you think otherwise, you can share with me product, and I will check if you where charged for same description two times. 2) Other issue, that I see and that could have caused this issue, and big charge of credits, and re-translation needed is that at some point category description was "translated" in the same language and you were charged for it. We need to check why this happened, and refund you for what was not translated correctly. Image attached. Let me know if both of mine points sound valid and you agree we continue to check the 2nd point and focus on that. Regards, |
| April 3, 2025 at 7:45 am #16890251 | |
nicolasF-24 |
Hi Drazen, 1) Please see your screenshot, the translation make the main content of the taxonomy French, in Spanish ... Whereas it's in French on the back office, not in Spanish. Tablero de equilibria is the translation of balance board in Spanish ... The taxonomy description don't change, and I'm sure of it because the person that was working on it left the company 6 months ago.. It's always the same problem, the wrong language is put in French and so WPML translate the description again and again Another example, but I have the same problem everywhere ... : hidden link I have start yesterday to check the categories one by one, I have to created a lot of "Product test" (you can check the log of yesterday), and corrected almost 40 categories, but I still have a lot to analysis (like the Zinc one previously for example that I have to recreate) 2) "is that at some point category description was "translated" in the same language and you were charged for it." |
| April 3, 2025 at 10:15 am #16891197 | |
Dražen Supporter
Hello, thanks for getting back. Great, that you provided and did some extra analysis, I think we have some clues here. First seems like you have been charged extra credits for no reason, and I will report this further, but first, let's try to see if this still happens and if there are any steps that cause it or have produced this. It might be a bug that we need to sort out first, so it does not happen again. If possible, provide us a staging site where we can further check this safely, and disable plugin/themes and etc. Regards, |
| April 4, 2025 at 7:44 am #16895584 | |
nicolasF-24 |
Hi Drazen, Unfortunately our admin server is in holidays right now so we can't propose you a fresh copy of the production on the dev server ... Can your team start to study the problem with the production ? I have a lot of product pending translations and I don't want to do them as soon as we didn't understand the problem ... Many thanks for your help |
| April 4, 2025 at 10:45 am #16896997 | |
Dražen Supporter
Hello, It would be difficult to check on production, since I need to try and test some steps, to see how the issue happens, then disable plugins, switch themes and etc to see if anything related causes it. We might also need to share it with our 2nd tier to check, all of this is not safe to do on a production live website. Please lets wait, and let me know once you have staging ready, and we can check it out further. Regards, |
| April 9, 2025 at 6:26 am #16911488 | |
Dražen Supporter
Hello, thanks. I have tried to disable most of the plugins, but that has caused an error. Can you please check and make sure I can check the site with only Wocommerce, ACF and WPML plugins active, all other disabled? Thanks, |
| April 9, 2025 at 7:03 am #16911597 | |
nicolasF-24 |
Hi Drazen, It's okay I adjusted the code |
