You are experiencing an issue where the same job appears in the related jobs section when viewed in a translated language on a site using WPML, BuddyBoss, and WP Jobmanager.
We recommend updating your BuddyBoss theme to Version 2.8.00. This update should resolve the issue of job duplication in the related jobs section across different language versions.
If this solution does not apply to your case, or if it seems outdated, please check the related known issues and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket with us for further assistance. You can do so at our support forum.
Last updated by Osama Mersal 1 year ago.
Assisted by: Osama Mersal.
January 3, 2025 at 9:05 pm #16562571
ericH-23
I am working on a site under development using WPML and Buddyboss and WP Jobmanager. I want to ensure that when a job is shown in a translated/duplicated language version, the related job area should not display the same job again.
When I switch to a translated language version of a job, the same job is shown in the related jobs section, which should not happen.
Why is the same job appearing in the related jobs section when viewed in a translated language?
How can I prevent jobs from appearing in the related jobs section in translated languages?
January 5, 2025 at 10:56 am #16564289
Osama Mersal
1) Please log in to this hidden link site and install the WP Job Manager plugin.
After that, please try to replicate the issue. If the issue is replicable, please let me know how to reproduce it so I can check it and consult our compatibility team.
Osama
January 6, 2025 at 7:03 pm #16567409
ericH-23
I added all needed plugins in the sandbox and have shown the error here:
FR: shown job is also at related
EN: shown job is NOT at related
It is needed, that in other languages also the same job is not shown under reletated jobs.
Thanks, kind regards
Eric
PS: debug I cancelled, because the error is shown in sandbox, so it has nothing to with my site especially
January 7, 2025 at 9:57 am #16568765
Osama Mersal
Thanks for replicating the issue on the sandbox site. Please check if the issue is fixed in the French language jobs.
Osama
January 16, 2025 at 8:34 am #16600244
ericH-23
Yes, the link hidden link shows now not the same job at the related jobs sections. Good!
What did you do and how I can take this over in my site?
Eric
January 16, 2025 at 8:38 am #16600317
Osama Mersal
Hi Eric,
Thanks for your confirmation. Please check the following steps:
1- Edit the /buddyboss theme/template-parts/related-jobs.php
2- Add the following code after line 12
// Get the current post ID
        $current_post_id = get_queried_object_id();
		// Initialize exclusion array with the current post ID
        $exclude_ids = array( $current_post_id );
        // Get the translated version of the current post in all languages
        if ( function_exists( 'wpml_object_id_filter' ) ) {
            global $sitepress;
            $languages = $sitepress->get_active_languages();
            foreach ( $languages as $lang_code => $lang_info ) {
                $translated_id = wpml_object_id_filter( $current_post_id, 'post', true, $lang_code );
                if ( $translated_id && ! in_array( $translated_id, $exclude_ids ) ) {
                    $exclude_ids[] = $translated_id;
        // Remove excluded IDs from the posts array
        $posts_array = array_diff( $posts_array, $exclude_ids );
3- Replace the following code
'post__in' => $posts_array,
'post__not_in' => array( $post->ID ),
With
Osama
January 17, 2025 at 2:39 pm #16606734
ericH-23
Thanks, I added the code and unfortunately have this result:
1) before in EN = no related jobs
2) before in DE = the same job below as related
3) after the new code = all test jobs shown at related
3) all different category jobs are shown here at related, but they are not related
Can you please check this? Could be that now the filter doesn't work anymore, so that not only "related jobs" are shown. I made a test and added a job with totally other text and category etc. and all the other jobs are shown below. So I think, now the related filter is not working anymore.
Eric
January 18, 2025 at 10:32 am #16608888
Osama Mersal
Hi Eric,
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
January 21, 2025 at 11:38 am #16618131
Osama Mersal
Hi Eric,
Would it be possible to run the following test on the staging site?
1- Deactivate all the plugins except those active ones on the sandbox site.
2- Switch to the parent theme.
❌ Please backup your database before performing the above test ❌
Osama
January 22, 2025 at 12:33 pm #16622878
ericH-23
Please check, I did what you suggested, the same result as before. Due to the other template please use now for login the wp-admin.
Eric
January 22, 2025 at 12:43 pm #16622925
Osama Mersal
Hi Eric,
Thanks for your reply. Please check if this job works as expected. (hidden link)
I applied the workaround to the parent theme as it wasn't applied there.
Osama
January 27, 2025 at 1:08 pm #16637851
ericH-23
Hi, Thank you, but I just tested the page and noticed that there's no footer under the jobs anymore. I can’t switch to other languages at all. I’ve already enabled BuddyBoss and Elementor, but I’m currently unable to activate the footer. I’m sorry, but I can’t make progress like this. Could you please tell me what I need to do and how I can test it afterward?
Kind regards
Eric
January 27, 2025 at 2:31 pm #16638386
Osama Mersal
Hi Eric,
I asked our compatibility team to check the issue on your site, and I'll update you as soon as they reply.
Kindly note that this issue has been escalated to our dev team queue, and they will communicate with the BuddyBoss team to find a permanent fix.
Osama
January 29, 2025 at 8:43 am #16644867
Osama Mersal
Hi Eric,
Thanks for your patience. Could you please let us know how the related jobs are working?
What's the logic behind it? Is there any option in the theme that says how the related posts are selected?
Osama
January 29, 2025 at 10:00 pm #16648791
ericH-23
Good question, I could show into the code but if you are talking with Buddyboss, could you please address this to their support?
If you need, I can search for the logic, please let me know.
Eric
