Last updated by Rut Abrado 1 year, 5 months ago.
Assisted by: Waqas Bin Hasan.
October 17, 2024 at 11:14 am #16299735
Rut Abrado
I've created a Custom Post Type (CPT) using ACF with some custom fields, and I have published several posts under this CPT, along with their translations using WPML. Now I need to change the post type key and have received the following advice: "You will need to run an SQL command to change the post type in the database: UPDATE wp_posts SET post_type= 'new_post_type' WHERE post_type= 'old_post_type';" In my case, I would use the command: UPDATE c0lab_posts SET post_type= 'grupos-electrogenos' WHERE post_type= 'generador-electrico';
I need to ensure that changing the post type key using this method will work for translated content without causing issues.
Could you please confirm whether this approach will work without causing issues for the existing translations?
Are there any additional steps or considerations I should take to ensure everything functions correctly with WPML?
The topic ‘[Closed] Changing Post Type Key on Translated Content with WPML’ is closed to new replies.
