Last updated by Ahmed Mamdouh 5 months, 1 week ago.
Assisted by: Ahmed Mamdouh.
March 16, 2025 at 8:52 am #16821145
walkmew
I changed the setting for 'Translation pickup mode' to 'The site will fetch translations manually.' I am trying to understand how this affects the status of jobs translated by the LILT translation service.
I am unsure of the status of translation jobs under WPML > Translation Management > Translation Jobs after setting the translation pickup mode to manual.
In what status will jobs translated by the LILT translation service appear under WPML > Translation Management > Translation Jobs when the translation pickup mode is set to manual?
Can you provide a REST API endpoint to check the status of jobs translated by the LILT translation service?
March 16, 2025 at 3:04 pm #16821824
Ahmed Mamdouh
Thanks for contacting our support forum.
first Let me explain briefly how the translation sync is working.
In WPML -> Settings there are 2 options for sync as shown in the screenshot you shared.
If you are using XML-RPC, the translations are automatically delivered to your website. Still, please note that using this option could be tricky because if for any reason the translation delivery is interrupted, this option will be disabled automatically to allow the client able to retrieve the jobs manually.
If you are not using XML-RPC, you can fetch them manually by going to WPML -> Translation management and clicking the "Check status and get translations" button or by clicking the sync button beside every job.
So the translation pickup mode is not related to the jobs status, it's an option that allows you either to pickup the completed translation manually or automatically.
The Jobs status is changed upon the status in the translation service, for example: if you just sent a new job, you will see its status as "in-progress", if it's completed in the translation service, you will see it as "completed" and so on.
I hope this answers your question,
Ahmed Mamdouh.
