You are experiencing a CORS issue where your .at domain is incorrectly sourcing its files from the .ch domain instead of the primary translation. This misconfiguration causes icons and fonts to be blocked due to CORS policies.
We recommend reaching out to your web hosting provider and requesting them to set the CORS policy specifically with the
Access-Control-Allow-Origin
header. This adjustment will allow your .at domain to correctly load content from the intended source domain. For detailed guidance on setting CORS policies, please visit: https://enable-cors.org/
If this solution does not resolve your issue or seems outdated, please check for related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. Should the problem persist, we highly recommend opening a new support ticket for further assistance.
Last updated by 1 year, 11 months ago.
Assisted by: Marcel.
