I am using Tutor LMS Pro and trying to populate the course contents (Topics, Lessons, and quizzes) in the secondary language. The courses and topics are displayed on the overview page but not on the detail page. I have duplicated a course, but the same issue occurs with the duplicated course. Link to a page where the issue can be seen: hidden link
Course contents are not appearing in the secondary language on the detail page, even though they are displayed on the overview page.
Why are the course contents not appearing in the secondary language on the detail page?
Is there a specific setting in WPML or Tutor LMS Pro that I need to adjust to fix this issue?
Thank you for contacting WPML support. I'd be happy to assist you on this issue.
Can you edit the courses manually using WordPress editor and links the contents and see if it works?
Further, We've recently rolled out a new version of WPML plugins. Could you please update your plugins to the latest version and inform me if it resolves the issue?
Our WPML updates are distributed gradually. If your websites haven't received this update yet, please be patient, and you should see it within a few days.
---> Yes I can edit the Arabic course mnually and add the course content manually that works fine.
---> All the Plugins are updated as per instruction.
Further More all the data is getting duplicated when i try to duplicate the course from English except the course contents of Tutor LMS Pro.
It seems that manual adjustments are currently the recommended workflow. As outlined in the documentation here: https://wpml.org/plugin/tutor-lms-pro/, you’ll need to handle the adjustments manually.
Translation is only possible through manual methods, which means the courses will also need to be set up manually.
I hope this clarifies things. Let me know if you have any questions!
The topic ‘[Closed] Course Contents are not appearing in secondary language’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
