Last updated by marcoM-185 8 months, 2 weeks ago.
January 2, 2025 at 1:02 pm #16558833
marcoM-185
I am experiencing ongoing issues with credits being lost on my site hidden link. The site seems to think I changed the HostName to an IP address. I have updated the wp-config file with all required information and memory parameters, and I have checked DNS and CNAME settings multiple times. Despite these efforts, the issue persists. When I remove and re-add the site, I often lose credits and have to request support to manually add them back to my account. The site mentioned is the only site I have, with no test or dev environments. Here are the parameters I have set: define('WP_HOME','hidden link'); define('WP_SITEURL','hidden link'); define ('WP_MEMORY_LIMIT', '256M'); define ('WP_MAX_MEMORY_LIMIT', '256M');
Credits are lost when the site incorrectly identifies a change from DNS domain to IP address.
Why does the site think the HostName has changed to an IP address?
How can I prevent losing credits when removing and re-adding the site?
January 2, 2025 at 5:01 pm #16559599
According to our system the site was move on the 28th of December.
Did you maybe change the server of this site or did you unregister and register the again?
I have now assigned the 190829 credits from the old site's organisation to the new organisation.
January 2, 2025 at 5:11 pm #16559615
marcoM-185
No I didn't move it
The problem is random
The error is coming back after days or months
The IP address domain etc did not change
I see the credit back
Still digging into all configuration to find out why it keeps coming back
with thinking I changed the site from domain to Ip addresses
Most of the case it comes back with the same error that I changed from up to domain name
I have tried to disable all plugin updates and removed disabled almost all without been able to find any difference
Today I have increased my memory on WP,
