The client is facing an issue where custom fields are not displaying on the frontend in translated versions of the website, despite being translated in the String Manager.
If you're experiencing this issue, we recommend you try the following steps:
1. Navigate to WPML-> Settings-> Custom Fields Translation section.
2. Select the "Show 'Multilingual Content Setup' meta box on post edit screen" option.
3. Click Save.
4. Edit the property in the default language.
5. Scroll down to the Multilingual Content Setup section.
6. Set those fields to Copy or Translate according to your needs.
7. Click Apply.
8. Update all the properties in the default language.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by 1 year, 1 month ago.
Assisted by: Osama Mersal.
