Last updated by Andreas W. 1 year, 6 months ago.
January 25, 2024 at 5:25 pm #15227608
chungwoo88
Hello.
I am using divi builder to made a website for Korean and English.
The fixed page can set the layout (font size, line-height, etc.) on each page in Korean and English, and we have done it successfully.
However, there are 2 CPTs on our site and line-height should be applied differently depending on the language.
We implemented two CPT through custom body through Divi theme builder.
I've tried many things, but unlike the page, I couldn't modify the line-height for each language in custom body.
Modifying the line-height in Korean also modifies the line-height in English.
Can we solve this problem?
January 25, 2024 at 10:17 pm #15228394
Usually, Divi Templates need to be translated with the WPML Translation Editor and this way it is not possible to use different layouts per language.
Please try this:
1) Go to WPML > Translation Management > Dashboard and filter the Divi Templates.
2) Then hover the mouse over the title of the template that you would like to translate.
3) A "Edit" option should appear, please click on it.
4) You should now see the WordPress Editor for this template.
5) Inside the right sidebar, at "Language" switch the translation method from "WPML Translation Editor" to "WordPress Editor".
6) Now, click the translate button (Pencil).
Are you now able to translate the template without the WPML Translation Editor?
Do the translations fit now?
The topic ‘[Closed] Divi theme builder custom body layout problem’ is closed to new replies.
