If you're experiencing cart duplication issues on your multilingual site, particularly when changing product quantities in languages other than English, it might seem related to WPML. However, the issue persists even when WPML is deactivated, indicating it is likely caused by another plugin or theme.
We recommend you perform the following steps:
1. Deactivate all plugins except for the essentials to see if the problem persists. This helps identify if any other plugin is causing the conflict.
2. Switch to a default theme temporarily to rule out any theme-specific issues.
3. If the issue is resolved by the above steps, reactivate your plugins and theme one by one to pinpoint the exact cause.
If these steps do not resolve the issue or if it appears complex, please open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
For further assistance, you can always contact us through our support forum at WPML Support Forum.
Last updated by pavelZ-3 1 year, 7 months ago.
Assisted by: Paola Mendiburu.
September 6, 2024 at 11:22 am
pavelZ-3
If you go to any product pages (for example Luxador MiLADY, or any other products pages) and add product to cart. Open cart and change quantity of product then there'll be no duplicates.
If you do the same steps but in German then it will show duplicated cart and every time when you increase or decrease quantity it'll show more and more duplicates.
I updates all plugins and WordPress version. I tried to deactivate plugins what probably could affect cart in popup but no results.
Can you help to solve this issue?
September 6, 2024 at 12:51 pm #16149111
Paola Mendiburu
WPML Supporter since 11/2020
Hi there!
I have created this test site:
Could you please add the cart to a popup and see if the problem is reproduced?
I have already created this product:
September 7, 2024 at 8:05 pm #16151763
pavelZ-3
unfortunately I can't to do that because for cart what we made on our sandbox we used Elementor Pro version and I don't have extra license to activate Elementor Pro on your sandbox.
Is there other options how we can run tests?
September 9, 2024 at 8:42 am #16154460
Paola Mendiburu
Don´t worry, I have installed elementor pro for you.
September 9, 2024 at 9:29 am #16154901
pavelZ-3
I added popup on sandbox and it duplicates cart content when I change product quantity.
But it started to happen when I translated popup before that when it was only in English everything works fine on both languages
I tested that on our sandbox and when I delete Cart Popup translation then it stops to duplicate content but when I add translation again it starts duplicate content
September 10, 2024 at 8:08 am #16159801
Paola Mendiburu
Thanks a lot.
I was able to reproduce the problem when I translate the header.
Now it is only happening on translation:
I am preparing to send it to the compatibility team.
I will let you know when I have news.
September 10, 2024 at 11:41 am #16160959
pavelZ-3
Thank you, I'll wait for updates
September 10, 2024 at 5:34 pm #16163095
Paola Mendiburu
Hi there!
I was doing more test and the issue persiste with WPML deactivated.
I have added the cart widget to the home page and as you can see the issue persists when WPML plugins deactivated, that means that it is not related to WPML.
September 12, 2024 at 11:47 am #16170634
pavelZ-3
I just did test on home page with cart and it's really interesting reaction.
I'll check cart widget and settings what we made and let you know if I get any answers
September 12, 2024 at 1:07 pm #16171210
Paola Mendiburu
Ok, the thing is that happens even if WPML is deactivated.
September 12, 2024 at 2:29 pm #16171830
pavelZ-3
I didn't find the reason why it's happening but if I don't add translation for cart popup then content doesn't duplicate and that's fine with me.
I translated Cart and Continue via css so now everything seems okay.
We can close the ticket. Thank you for your time and help.
