The client is using the Elementor theme editor to create post content pages and has set up custom CSS in Elementor. While it works fine in the main language, the CSS does not work when switching to a translation.
We recommend setting the
_elementor_page_assets
custom field to "copy" in the WPML settings. This action should copy the CSS to the translated template, ensuring that the custom styles appear correctly in the translated versions of the pages.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by jia-chunW 2 years, 9 months ago.
Assisted by: Osama Mersal.
October 14, 2022 at 5:59 am #12240183
jia-chunW
I adjusted the _elementor_css of the custom field translation to "copy" in the WPML settings
https://wpml.org/forums/topic/page-losing-custom-css-upon-update/
I have used elementor theme editor to create my post content pages, and then I have set up custom CSS in elementor.
It works fine in the main language, but when I switch to translation the CSS is not working.
October 16, 2022 at 8:12 am #12248685
Osama Mersal
WPML Supporter since 02/2020
First of all, sorry for the late reply due to a higher workload. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Thanks for your cooperation and patience
Osama
October 17, 2022 at 8:16 am #12251567
Osama Mersal
Thanks for the access details. I couldn't find the CSS while Editing this post using Elementor. Could you please tell me where to find the custom CSS for this post?
Osama
October 18, 2022 at 2:23 am #12257349
jia-chunW
Hi
I'll show you the steps to view the location of the CSS via the video link below.
October 18, 2022 at 7:44 am #12258769
Osama Mersal
Thanks for your update and the video. I set the "_elementor_page_assets" field to copy, which copied the CSS to the translated template. (Kindly check the attached screenshot)
Would you please check it and let me know if the posts work correctly?
Osama
