Last updated by Osama Mersal 11 months, 3 weeks ago.
Assisted by: Osama Mersal.
September 17, 2024 at 9:58 am #16187361
amazing-ideasM
I have a site under development using Elementor Pro. I created a form with a checkbox options field that contains 3 values/options to choose from. When I try to translate the page using WPML, all the values are presented in a single line.
Instead of having 3 radio buttons in the second language, I only have one option because of the translation.
What can I do to ensure the checkbox options are correctly separated in the translated page?
September 17, 2024 at 11:11 am #16187786
Osama Mersal
WPML Supporter since 02/2020
1) Please apply the 2nd workaround mentioned on this page.
After that, please re-translate the form to fix this issue.
2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
Osama
September 17, 2024 at 3:40 pm #16189697
amazing-ideasM
Hi Osama,
Thank you for the fast answer. I did exatly what you said, including the "memory_limit".
I already edited the options from the field in the wpml translete editor (e.ate...) as you can see in the picture. But, in the front-end website, it still appears the old translation and only one option. Do i need to do something else? This error already happened in other situations, i translate something in the back-end and it doesn't update in the front-end. I already tried to do a small change a reupload the translation but it also didn't work.
I have a question: after i translate the options from the field (like i did), can i activate again the “I prefer bigger segments” again? I don't want every paragraph separated unless it's in this case, but i already updated the form (
supposedly).
September 17, 2024 at 3:46 pm #16189733
Osama Mersal
Thanks for your reply. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
The topic ‘[Closed] Elementor (Pro) Form Checkbox Options Values aren’t separated’ is closed to new replies.
