Last updated by Bigul 1 year, 10 months ago.
Assisted by: Bigul.
February 12, 2024 at 1:13 pm #15293323
mathiasP-9
Changing a featured image but it wont change.
Followed other post about the same issue but nothing helps.
February 12, 2024 at 5:08 pm #15294191
Bigul
Just to make sure, are you trying to set different featured images for a post in primary and secondary languages?
Please open the relevant post/page for editing and check the following *Media attachments* options are selected in the WPML Language widget of the edit screen(on the right side).
- Duplicate uploaded media from the original
- Duplicate featured image from original
Bigul
February 13, 2024 at 6:58 am #15295619
mathiasP-9
Hello!
I have uploaded a image of an example.
February 13, 2024 at 8:44 am #15295927
Bigul
Thank you for the updates. A couple of requests for tracking this issue.
1) Please share the URL of a couple of posts having this issue
2) Please fill the private details fields after a full site backup{mandatory}. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information-sharing policies.
Bigul
February 14, 2024 at 8:56 am #15300584
Bigul
Thank you for the login information. Please share the URLs of the posts in the following screenshots. I'm unable to locate them exactly.
Bigul
February 14, 2024 at 9:34 am #15300761
mathiasP-9
This was the product that i had issue with and was the first that the customer changed the picture, but it looks like it working fine on the others.
I had to change this one manualy.
February 14, 2024 at 10:37 am #15301342
Bigul
Thank you for the updates. Please check the attached images. Now the same image is showing for the original language post and its translation. So just to make sure you are getting the expected result now, am I correct.
Bigul
The topic ‘[Closed] Featured Images are not copied when translated’ is closed to new replies.
