9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Last updated by Christopher Amirian 1 year, 4 months ago.
December 17, 2024 at 8:57 am #16520408
beverlyL
I am using the Swimi theme for my website hidden link. I have finished translating the footer using WPML, but the English content is not displaying.
The website is only showing the footer in French, the default language, no English footer in English side.
Why is the translated footer not displaying in English?
How can I ensure the footer translation appears correctly on the website?
December 17, 2024 at 12:00 pm #16521537
Christopher Amirian
WPML Supporter since 07/2020
Welcome to WPML Support. I checked the footer of the website and it seems to be created by Elementor.
Please follow the steps below to translate the Elementor template for the footer:
https://wpml.org/documentation/plugins-compatibility/elementor/#translating-elementor-templates
Also please increase the PHP memory limit:
The minimum requirement is 128M but I suggest that you increase it to 512M: https://wpml.org/home/minimum-requirements/
You can add this by adding the code below to "wp-config.php" file of your WordPress installation root folder:
/** Memory Limit */
define('WP_MEMORY_LIMIT', '512M');
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
Please add the code above the line below:
And finally, if the theme you use has an option to select the footer template, you need to translate that in the string translation:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
If the issue persists, I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
December 19, 2024 at 2:36 pm #16530580
Christopher Amirian
Hi Gary,
The theme uses the template ID to show the footer so I tried the following steps:
1- Go to WPbingo > Footers
2- Get the original footer ID (29654)
3- Switch the language to English from the top admin bar and get the English footer ID (41166)
4- Go to WPML-> String Translation-> Translate Admin Text, and search for the original ID
5- Select the string and add it to String Translation
5- Go back to the String Translation page and use the English ID as a translation of the original
Now the English Footer shows on the inner pages:
But I am not sure why it is not showing on the homepage. I wonder if you selected to have a separate footer for the homepage? or there is some sort of cache happening?
FYI, I will be off the next 2 days so the next answer will be longer.
The topic ‘[Closed] footer not translated to English’ is closed to new replies.
