Last updated by Andreas W. 1 year ago.
March 12, 2025 at 2:11 pm #16807634
nikiforosB
I am trying to get data from Jet Engine's custom meta storage for CPTs. This feature creates a new database table that stores all metaboxes for this CPT. I am unable to find anything in the WPML settings or string translation to get these data for translations.
I cannot find anything in the WPML settings or string translation to get these data for translations.
How can I access Jet Engine's custom meta storage data for translation in WPML?
March 14, 2025 at 7:41 am #16814703
It might be the case, that as this is a feature that is in "beta" it is not yet supported by WPML.
Have you already tried to search for the fields at WPML > Settings > Custom Field Translation?
If the fields do not appear there, then we might not be able to translate them together with your CPTs using the WPML Translation Editor.
A workaround might be to scan the JetEngine Plugin for new strings at WPML > Theme & Plugin Localization and then try to find and translate the meta information at WPML > String Translation.
If this will not solve the issue, please let us know.
The topic ‘[Closed] Get data from Jet Engine Custom Meta storage’ is closed to new replies.
