Last updated by Bobby 1 year, 6 months ago.
Assisted by: Bobby.
October 17, 2024 at 9:35 pm #16302110
Dimitri
I am trying to use Gravity Forms Multilingual 1.8.0 and over, but the filter 'gform_review_page' does not display the review page as expected. See filter doc here: hidden link. I downgraded to Gravity Forms Multilingual 1.7.2 to solve the issue. It would be great to fix this in the next release 1.8.3.
I expected to see the button to see the review page. Instead, I got no button to the review page. It shows directly the submit button.
Why does the 'gform_review_page' filter not display the review page as expected in version 1.8.0 and over?
Is there a fix planned for this issue in the next release 1.8.3?
October 21, 2024 at 6:07 pm #16313962
Bobby
WPML Supporter since 04/2015
This is a list of known issues with Gravity Forms and WPML, however, I do not see one related to the review page.
I created a sandbox environment for us to investigate this issue further.
Please use this link to log in and upload Gravity Forms. Once finished, I will be able to further investigate and update you.
October 28, 2024 at 11:14 am #16337368
Dimitri
Just follow the documentation (hidden link) of gravity Forms to replicate the issue.
You need to do it thru a child theme and add a filter in the functions.php file to activate this feature.
add_filter( 'gform_review_page', 'your_function_name' );
Regards
October 28, 2024 at 6:35 pm #16339466
Dimitri
I've installed Gravity Forms plugin, Installed a child theme and modifyied the functions.php file to activate the review page and I have a Fatal error when I tried to display the test page.
October 28, 2024 at 9:26 pm #16339793
Bobby
This is the error I received.
add_filter( 'gform_review_page', 'wpml_review_page' );
function wpml_review_page( $review_page, $form, $entry ) {
return $review_page;
Fatal error: Uncaught ArgumentCountError: Too few arguments to function wpml_review_page()
Fatal error: Uncaught ArgumentCountError: Too few arguments to function wpml_review_page(), 1 passed in /var/www/sites/best-cavaco/wp-includes/class-wp-hook.php on line 326 and exactly 3 expected in /var/www/sites/best-cavaco/wp-content/themes/twenty-twenty-four-child/functions.php:18 Stack trace: #0 /var/www/sites/best-cavaco/wp-includes/class-wp-hook.php(326): wpml_review_page() #1 /var/www/sites/best-cavaco/wp-includes/plugin.php(205): WP_Hook->apply_filters() #2 /var/www/sites/best-cavaco/wp-content/plugins/gravityforms/gravityforms.php(7332): apply_filters() #3 /var/www/sites/best-cavaco/wp-content/plugins/gravityforms/form_display.php(367): gf_apply_filters() #4 /var/www/sites/best-cavaco/wp-content/plugins/gravityforms/form_display.php(1054): GFFormDisplay::maybe_add_review_page() #5 /var/www/sites/best-cavaco/wp-content/plugins/gravityforms/gravityforms.php(3607): GFFormDisplay::get_form() #6 /var/www/sites/best-cavaco/wp-content/plugins/gravityforms/gravityforms.php(2272): GFForms::get_form() #7 /var/www/sites/best-cavaco/wp-includes/shortcodes.php(434): GFForms::parse_shortcode() #8 [internal function]: do_shortcode_tag() #9 /var/www/sites/best-cavaco/wp-includes/shortcodes.php(273): preg_replace_callback() #10 /var/www/sites/best-cavaco/wp-includes/class-wp-hook.php(324): do_shortcode() #11 /var/www/sites/best-cavaco/wp-includes/plugin.php(205): WP_Hook->apply_filters() #12 /var/www/sites/best-cavaco/wp-includes/blocks/post-content.php(50): apply_filters() #13 /var/www/sites/best-cavaco/wp-includes/class-wp-block.php(519): render_block_core_post_content() #14 /var/www/sites/best-cavaco/wp-includes/class-wp-block.php(499): WP_Block->render() #15 /var/www/sites/best-cavaco/wp-includes/blocks.php(2061): WP_Block->render() #16 /var/www/sites/best-cavaco/wp-includes/blocks.php(2113): render_block() #17 /var/www/sites/best-cavaco/wp-includes/block-template.php(260): do_blocks() #18 /var/www/sites/best-cavaco/wp-includes/template-canvas.php(12): get_the_block_template_html() #19 /var/www/sites/best-cavaco/wp-includes/template-loader.php(106): include('...') #20 /var/www/sites/best-cavaco/wp-blog-header.php(19): require_once('...') #21 /var/www/sites/best-cavaco/index.php(17): require('...') #22 {main} thrown in /var/www/sites/best-cavaco/wp-content/themes/twenty-twenty-four-child/functions.php on line 18
Maybe if we get a staging copy of your site it will help to better reproduce the issue.
If possible i would like to take a closer look at the backend to further test this issue
**Before we proceed I recommend to please take FULL BACKUP of your database and your website.**
I often use the Duplicator plugin for this purpose See: http://wordpress.org/plugins/duplicator/
I would like to request temporary access (wp-admin and FTP) to your site to fix the issue.
NOTE: if access to the live site is not possible and staging site does not exist please provide me with a duplicator package created with the duplicator plugin
Thank you,
Bobby
October 31, 2024 at 1:46 pm #16351608
Dimitri
I don not have access to the sandbox site anymore because of this error:
Parse error: syntax error, unexpected integer "3" in /var/www/sites/best-cavaco/wp-content/themes/twenty-twenty-four-child/functions.php on line 19
I guess you change something in the code.
Could you please check ?
I can not duplicate this site, sorry.
October 31, 2024 at 10:59 pm #16353528
Bobby
I have created a new sandbox for us, the original one has crashed due to testing the code.
Do you happen to have a staging site or just the live site at the moment?
Also I used this code and it seemed to work OK
add_filter( 'gform_review_page', 'add_review_page', 10, 3 );
function add_review_page( $review_page, $form, $entry ) {
// Enable the review page
$review_page['is_enabled'] = true;
if ( $entry ) {
// Populate the review page.
$review_page['content'] = GFCommon::replace_variables( '{all_fields}', $form, $entry );
but it did not generate a review page at the top of the page.
The topic ‘[Closed] Gravity Fomrs Multilingual issue with filter “gform_review_page”’ is closed to new replies.
