You are encountering repeated appearances of 'Header Menu' and 'Footer Menu' in translations on your website.
First, check if there are any draft versions of these menu items in your website. If you find any, we recommend deleting them to see if this resolves the issue. If this does not solve the problem, please provide us with detailed information on how the 'Header Menu' and 'Footer Menu' items were created and where they appear on your website.
If the solution provided here does not apply to your case, or if it seems outdated, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
Last updated by Lucas Vidal de Andrade 6 months, 1 week ago.
February 25, 2025 at 10:11 am #16744874
giladT
I am trying to fix the 'Header Menu' and 'Footer Menu' on my site hidden link. I see these terms many times in the translation process.
Repeated appearance of 'Header Menu' and 'Footer Menu' in translations.
How can I fix the 'Header Menu' and 'Footer Menu' issues?
February 25, 2025 at 4:22 pm #16746953
WPML Supporter since 11/2023
Hey there,
All the duplicates are set as drafts. Perhaps they're saved that way in your website. Please check and delete any of the drafts, if they exist.
If that's not the case, please tell me in detail, how the 'Header Menu' and 'Footer Menu' items were created and where they show on your website.
