The client is experiencing issues with variable products' translations not showing variations.
If you're facing similar issues, we recommend you try the following steps:
1. Navigate to WPML -> Support -> Troubleshooting.
2. Run the functions one by one. Kindly check this documentation.
3. Edit the product in the default language.
4. Change the variation price and update the product.
5. Change the variation price back and update the product.
6. Update the product's translation.
7. Clear the site's cache and check the translated product on the front end.
Please ensure to backup your database before performing the above steps.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by Osama Mersal 1 year, 9 months ago.
Assisted by: Osama Mersal.
June 10, 2024 at 11:25 am #15721783
dannyL-2
Additionally, the variable products' translation doesn't show variations.
e.g. hidden link
it's translation: hidden link
Please help to advise on how to make the translated variable products show options.
June 10, 2024 at 11:29 am #15721788
Osama Mersal
Please try the following steps:
1- Go to WPML-> Support-> Troubleshooting
2- Run the functions one by one (Kindly check this hidden link)
3- Edit the product in the default language
4- Change the variation price and update the product
5- Change the variation price back and update the product
6- Update the product's translation
7- Clear the site's cache and check the translated product on the front end
❌ Please backup your database before performing the above steps ❌
Osama
June 10, 2024 at 12:03 pm #15721863
dannyL-2
Thank you very much. It works.
