Home›Support›English Support›[Resolved] How to translate GiveWP donation forms into English (my default language is italian)
Problem: The client needs to translate donation forms from Italian to English using WPML, but only the title of the form is translatable through the WPML interface. The forms are built with a visual builder that is not yet compatible with WPML.
Solution: We recommend using a custom code snippet to manually assign a language to the form. Here is the code you should use:
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at https://wpml.org/forums/.
I have my site in Italian and I need to translate the two donation forms into English, which is my second language. I am using WPML translation tools.
When I go into WPML>gestioni traduzioni and choose Form, I can only translate the title of the form.
What am I supposed to do to have the same form in Italian and English?
Hi Mihai,
there is an Hidden Link and I couldn't figure out how to do it.
If you can assign it to one of your colleagues who can help me would be very happy.
Give has a documentation page that I link you here
but alas I didn't understand I set up what they suggest but I couldn't configure it correctly (I also opened a new ticket with Give Wp at the same time)
I'm Osama from WPML forums support. I'll be glad to help you today.
First of all, sorry for the late reply; it was due to a higher workload.
1) Please log in to this hidden link and install GiveWP. Then, create a test donation form to replicate the issue.
If the issue is reproducible, please let me know so I can investigate and consult our compatibility team if necessary.
Hi Osama,
I've been going crazy since yesterday about this translation,
if you go here and scroll down the module has been partly translated into English (within the module itself hidden link) and partly instead it still has strings in Italian that I cannot in any way translate I have tried everything, the strings the .po files everything but to no avail.
If you click on the DONATE NOW button here:
it opens the correct form (translated for good and I don't know how come being the same one you find in the above page) only the payment information is doubled????
Can I share with you the login to get into my amdin, while i configure give wp on the test site
Please help me!
THank you
Thanks for your update. Sure, I would need to request temporary access (WP-Admin and FTP) Preferably to a test site where the problem has been replicated.
1) Thanks for the access details. I was able to fix the "hidden link" button issue by editing the hidden link and translating the button.
2) I couldn't fix the issue on the hidden link form. Please replicate this issue on the sandbox site and let me know to consult our compatibility team.
HI OSAMA,
thanks for the button, ok i will ri-create the form and also the pop up that opens if you click on the DONATE NOW button did you understand why there is the:
1 - Accetti condizioni in italian (and not in english...no one string available to translate it)
2- Donation summury duplicate twice (see attached)
It's not clear why some parts are well translate and some other not!
Thanks you so much Osama for now.
I will send an other message when i replicate the issue on the sandbox site.
Best,
Silvia
PS: hope to find soon the solution as my client is not so happy for that.
THANKS! a need to figure it out why the string "accetti le condizioni" is stil in italian?
do you have any ideas? Ans also the if you click on SHOW TERMS the lines are in italian too!!!!
where I have to go to traduce that part?
Hi Osama,
I have solved the terms, and now these are translated.
I still have to understood why if i click in the home page and click on the fisrt up button DONATE NOW it works EVEN IF the button in DONA ORA and not DONATE NOW (1-.jpg)
also if you scrool down and click on the other DONATE NOW BUTTON the pop up that open has a duplication (2-.jpg)
at the end the donation form more or less is ok but see the final attached (3-.jpg).
the button is wrong (what have you done to change it...it was in on other page)
Thank you for now,
in the form there always some untranslated words...
i haven't have yet the time to move the module on the site you gave me.
if we solve this issue maybe is not necessary because this operation needs time by my side.
