The client is attempting to use "uk" as a custom language code for a variation of English on their website. They have manually changed the Ukrainian language code in the database to "urk" to free up "uk", but this resulted in redirection to the French version of the site.
We advise against manually editing the database records for pre-existing languages, as it can lead to unexpected behavior. Instead, we recommend adding Ukrainian as a language in WPML, then navigating to WPML -> Languages -> Edit Languages. Here, you can change the language name to something like "English-UK" and adjust the default language locale and hreflang to match the English (UK) settings. After these changes, the client should be able to access their site using the
site.com/uk/
URL.
If this solution does not seem relevant to your situation, please open a new support ticket with us.
Last updated by Sajjad Saleem 1 year, 7 months ago.
Assisted by: Bobby.
January 4, 2024 at 8:47 pm #15152960
Sajjad Saleem
I am trying to use "uk" as a language code for a custom language. It is another variation of English.
I changed previously held ukrainian language code to urk in database to make space for uk but it is still not working. It redirects to french when I do this.
When I enter this, hidden link. It takes me to hidden link. It is wrong.
No
I am using "ca" code here using nginx, but I want to utilize wpml. hidden link
January 4, 2024 at 10:22 pm #15153081
Bobby
WPML Supporter since 04/2015
Please note that we highly discourage you from editing the database records of the pre existing languages as this can cause unforeseen results and not work as expected.
The pre loaded languages will use standard procedures with the language codes therefore this is based on ISO values and WordPress values.
Now to achieve what you would like to achieve the best way would be to add the Ukrainian language, and go to WPML->languages->Edit languages and from there edit the language name to English-UK for example, as well as changing the default language locale to match the EN UK one along with the hreflang.
Once this is finished you should be able to use the site.com/uk/ URL.
January 5, 2024 at 5:35 pm #15155979
Sajjad Saleem
I have done a database reset and then used these steps. It is still redirecting it to /fr/.
hidden link is redirecting to hidden link
Screenshot 2024-01-05 at 22-34-11 Languages ‹ BIONIC® Dog Toys — WordPress.png
January 5, 2024 at 5:51 pm #15156090
Sajjad Saleem
I had to create a homepage for this language and it worked.
