Home›Support›English Support›[Resolved] I am managing a multilingual site in Spanish with translations to English and Japanese using WPML. I...
Problem: When WPML String Translation is activated, the Japanese version of the Woocommerce cart leads to a 404 error page. Disabling WPML String Translation allows the cart to be visible, but some pages do not display information correctly. Solution: If you're experiencing this issue, we recommend you try the following steps: - Go to WPML -> Settings -> Post Types Translation -> Products (product) - Click on 'Set different slugs in different languages for Products' and ensure that the slug for the Japanese version matches those of other languages, such as setting it to 'tienda' to align with the Spanish and English versions. After these adjustments, the Japanese cart page should start loading correctly.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
When WPML String Translation is activated, the Japanese version of the Woocommerce cart leads to a 404 error page. Disabling WPML String Translation allows the cart to be visible, but some pages do not display information correctly. This issue has started occurring recently as it was functioning correctly a month ago
I tried removing the wc/file/transient string and wc_api with no luck.
When WPML String Translation is activated, the Japanese version of the Woocommerce cart leads to a 404 error page. Disabling WPML String Translation allows the cart to be visible, but some pages do not display information correctly. This issue has started occurring recently as it was functioning correctly la month ago
Languages: English (English )Portuguese (Brazil) (Português )
Hello There,
I understand the issue you're having. In one case, I found that the 404 error occurred due to translating some new WooCommerce endpoints. Could you please try the following steps and check if they help resolve the issue?
1. Please activate the String Translation plugin and then go to WPML > String Translation.
2. Search for wc/file/transient.
3. If that appears in the result, delete the string from the list.
4. Search again for wc-api, and if you find that string, delete it as well.
Once they are deleted, please try accessing the Japanese cart page again.
If the issue persists, you can try renaming the cart page slug. Here's what you need to do:
1. Locate the Japanese cart page and click on the "Quick Edit" link below the page name.
2. Make a small change to the page slug and save the changes.
3. Once done, go to "Settings > Permalinks" and resave the permalink structure.
Please give the steps a try and let me know how it goes. I will be happy to help if you need further assistance in this matter.
Our Debugging Procedures
Please, let me know if you need any additional details. Have a nice day.
Hello there,
I was able to fix this issue following the steps:
- I clicked on 'Set different slugs in different languages for Products.' and noticed that only the Japanese version was different in there
- I set it to 'tienda' following the Spanish and English versions
After that, the Japanese cart page starts loading again.
The URL of the store page in Japanese didn't get affected by this change.
Can you please test it again and confirm that everything is OK now?
