The client is trying to translate Product Filters for WooCommerce and has switched to Yith product filters due to compatibility issues. Despite translating the labels with WPML, they do not appear on the website.
First, we recommend checking our compatibility list to ensure the plugin you are using is compatible with WPML. You can also search for the plugin's compatibility with WPML on Google by typing 'WPML+plugin name'. For example, you can find information about JetSmartFilters here: https://wpml.org/plugin/jetsmartfilters/.
Additionally, we have added the translated filter shortcode to the translated Archive template on your site. Please verify if this resolves the issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket.
Last updated by Osama Mersal 6 months, 2 weeks ago.
Assisted by: Osama Mersal.
January 27, 2025 at 10:58 am #16637216
lodeV-4
I am trying to translate Product Filters for WooCommerce, the official WooCommerce extension, on my site hidden link.
I can't figure out how to translate Product Filters for WooCommerce.
January 28, 2025 at 10:36 am #16641017
Osama Mersal
WPML Supporter since 02/2020
1) Would you please share screenshots or a screen-recorded video while reproducing the issue to help me understand it better?
Osama
January 31, 2025 at 11:19 am #16655107
lodeV-4
When I translate mu Dutch site to English, the filter titles don’t translate and the filter displays all its information at once
January 31, 2025 at 11:48 am #16655267
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
January 31, 2025 at 9:29 pm #16657234
Osama Mersal
Thanks for the access details. I edited the translated archive template using Elementor and added the "Filters for product archive en" shortcode, but it didn't appear on the front end.
Please log in to this hidden link">sandbox site and install the filters plugin only. After that, please create a test filter to replicate the issue. Please let me know if the issue is replicable so I can check it and consult our compatibility team.
Osama
February 1, 2025 at 4:45 pm #16658637
lodeV-4
I added the plugin to the website, but I am not able to recreate the issue, because I don't see the "templates" page and I normally work with Elementor. Hope you can help me in another way too?
Thanks in advance!
February 2, 2025 at 9:34 am #16659702
Osama Mersal
1) Thanks for your reply. I installed Elementor and Elementor Pro on the sandbox site. Please check if you can replicate the issue.
2) Please update the products filter plugin to the latest version.
Thanks for your cooperation
Osama
February 2, 2025 at 4:37 pm #16660352
lodeV-4
I switched plug-ins and am now using WCAPF - Woocommerce Ajax Product Filter. Everything works fine now, but I can not translate the labels from the filters. Is there a way I can do this?
Kind regards
February 2, 2025 at 4:47 pm #16660366
Osama Mersal
Please install it on the sandbox site so I can check it.
Osama
February 2, 2025 at 9:00 pm #16660573
lodeV-4
Thank you for your time. I installed the plugin, but apparently the filters can't be displayed because "The free version of the plugin does not support filtering products on singular pages. Upgrade to the Pro version to unlock this feature.".
On my site it works fine, and I also have the free version. Hope you can help me like this too.
February 3, 2025 at 8:22 am #16661369
Osama Mersal
Thanks for your update. I was able to fix the issue on the sandbox site by the following steps:
1- Go to WPML-> Settings-> Post Type Translation section
2- Set the following post types to "Translate - Show Only Translated Items"
* Filter Forms (wcapf-form)
* Filters (wcapf-filter)
3- Go to WPML-> Translation Management
4- Search for the filter and send it to translation
5- Complete the filter translation
6- Edit the translated filter using the WordPress editor
7- Add the translated categories and attributes
After that, the filter appears correctly in both languages. Please check the sandbox's hidden link">shop page.
Osama
February 3, 2025 at 11:04 am #16662333
lodeV-4
thanks for your help. I translated the filters in WPML, but they don't appear on my site. Is there something I am doing wrong?
Kind regards
February 3, 2025 at 11:17 am #16662374
Osama Mersal
The translated form was a draft, so I published it. Please check if the translated filters appear correctly on the front end. (hidden link)
Osama
February 3, 2025 at 11:21 am #16662381
lodeV-4
thank you very much. But not all the translations appear correctly on the site.
February 3, 2025 at 11:45 am #16662451
Osama Mersal
I think you need the pro version in order to be able to translate these filters correctly using Elementor.
Before buying it, please consult the WCAPF support team about this issue and ask them if the pro version will fix it.
I'm saying this because I checked their documentation, which mentioned that you need the pro version to use it correctly with Elementor single templates.
Osama
