Last updated by Bigul 1 year, 8 months ago.
Assisted by: Bigul.
August 9, 2024 at 12:33 pm #16056438
orir-3
I had Loco Translate plugin and started using your plugin. I am trying to upload a .po file and it doesn't work.
i also have problem with the checkout page,this problem hasnt been,its mean if i upload my backup without your plug in it whould be ok.
The .po file upload does not work.
What could be causing the .po file upload to fail?
Are there specific steps to follow for uploading .po files in WPML?
August 9, 2024 at 4:33 pm #16057297
Bigul
We can import the *.po file after choosing the string domain. Please check the following documentation and attached image for more details.
https://wpml.org/documentation/getting-started-guide/string-translation/#import-export-po-files
https://wpml.org/faq/how-to-generate-a-po-file-for-a-plugin-or-a-theme/
Are you getting any warning or error while uploading the .po file?
Bigul
The topic ‘[Closed] i had loco translate plug in and start using your plug in’ is closed to new replies.
