The client was unable to find where to translate the text "læs mere" to "read more" for the English language on their website.
1. We recommended the client to go to WPML > String Translation and scroll to the bottom of the page.
2. Select the option "Look for strings while the page is rendered", visit the page, and refresh it.
3. Then, return to WPML > String Translation, disable the option, and search for the string. It should now be available for translation.
If the string is showing with the incorrect language flag:
1. Check the box on the left of the string.
2. Scroll down a bit and select "change language of string".
3. Change it to Danish, so that the one showing at the moment with the EN flag will have the Danish flag.
4. Then, on the right side, you will be able to add the English translation.
If the solution provided here is not relevant to your case, because it might be outdated or not applicable, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket. You can reach our support forum here: https://wpml.org/forums/forum/english-support/.
Last updated by Mihai Apetrei 1 year, 8 months ago.
Assisted by: Mihai Apetrei.
April 3, 2024 at 11:30 am #15477716
Dennis
I can't find the place for translating the text "læs mere" to read more for English language.
April 3, 2024 at 12:34 pm #15478375
Dražen
Thank you for contacting WPML support. While you are waiting for one of my colleagues to take this ticket and work on it, let me provide you with the first debugging steps and try to help with the issue quickly.
Please go to WPML > String translation and scroll to the bottom of the page, select the option "Look for strings while the page is rendered", visit your page, and refresh it. Then go back to WPML > String translation disable this option and search for your string. It should appear there and you can translate it.
Let us know how it goes.
Drazen
April 3, 2024 at 12:42 pm #15478443
Dennis
That worked.
It seems like the English sentence is in danish?
See attachment
English = read more
Danish = læs mere
April 3, 2024 at 10:16 pm #15480598
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
It seems that you are right: the wrong language flag is selected for that string.
Please check the box on the left, then scroll down a bit, select "change language of string" and change it to Danish, so that the one showing at the moment with EN flag will have the Danish flag and then, on the right side, you will be able to add the EN translation.
I hope that you will find this information helpful. 🙂
Mihai Apetrei
April 4, 2024 at 4:02 am #15480901
Dennis
Nice Mihai. Very simple to understand. Thanks for the help with this issue.
