The client needs help with a translation issue but did not provide specific details about the problem.
We recommend that you provide more detailed information about the translation issue you are encountering. If possible, attach screenshots to help clarify the problem. You can use the "upload an image" option below the comment area on our support page.
Please note that the solution provided here might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by 2 weeks, 6 days ago.
Assisted by: Andrey.
