Last updated by oldrichH 11 months ago.
Assisted by: Noman.
April 9, 2025 at 9:39 am #16912281
oldrichH
I’m trying to audit all currently installed plugins on my site and determine which of them are not compatible with WPML. I have found pages like this one: https://wpml.org/plugin/ultimate-member/, but I don’t really understand how to navigate the plugin compatibility section. The certified plugin gallery doesn’t allow searching by plugin slug or list all installed plugins for comparison.
Although Ultimate Member has known issues when used with WPML, it is not listed on https://wpml.org/known-issues/ – which gives the impression that everything works fine. This makes it difficult to proactively detect problems before they occur in production.
Is there any built-in functionality in WPML or any tool that could help cross-check currently active plugins against a real compatibility list?
Even just knowing which plugins are known to cause issues would be very helpful.
The topic ‘[Closed] I need to audit, which installed plugins are not compatible with WPML.’ is closed to new replies.
