Last updated by Dražen 1 year, 6 months ago.
February 22, 2024 at 12:13 pm #15333420
nikolaosX-3
I need to import posts (custom post type) using "WP All Import" and "WPML Export and Import" plug-in.
I watched some easy-to-follow tutorials using the "WPML All Import" add-on. However, when I try to download it from your website, it asks to download the newer "WPML Export and Import", which requires a specific format of tables before import. I have 1000 posts from a client and it is impossible to change the format now.
My final goal is to be able to import the categories (custom taxonomy) first, as shown in most tutorials, and the posts (custom post type) in the default (Greek) language, and then in English.
Is it possible with "WPML Export and Import"? If not, is there a way to download the older "WPML All Import" add-on? Any guidance with any plug-in in order to achieve my goal will be greatly appreciated.
Thanks in advance.
February 22, 2024 at 1:23 pm #15333748
Dražen
Thank you for contacting WPML support. While you are waiting for one of my colleagues to take this ticket and work on it, let me provide you with the first debugging steps and try to help with the issue quickly.
Sure, it is possible to use and achvie this without WPML Export and Import, for now.
You can follow our guide:
- https://wpml.org/documentation/related-projects/wpml-all-import-plugin-website-import-with-wpml/importing-multiple-languages-with-wp-all-import-and-wpml/
and download addon plugin from:
- https://wpml.org/download/wpml-all-import/?section=changelog
Drazen
February 23, 2024 at 12:06 pm #15337527
nikolaosX-3
Thank you very much for your quick response! All I actually needed was the link to the plug-in.
