keep the same alternative text for images between languages
Go to WPML-> Sittings-> Custom Fields Translation section, then type “_wp_attachment_image_alt” on the search box, and set it to copy
0% of people find this useful.
Last updated by ioannisB-7 4 years, 7 months ago.
Assisted by: Osama Mersal.
January 22, 2021 at 10:43 pm #7909317
ioannisB-7
When translating a product I can see all its images (and the option to change their names, alternative text, etc). For my purposes I will never need to change images between two languages, either its name or alternative text. But as you can see in the picture alternative_text.png the text isn't transferred to the other language and I will have to either write it again or press the copy button and I am afraid somebody will forgot too. So I would like the alternative text to be passed over the translation as happens with the image name.
No
Look at the image
chimeracraft.gr
January 24, 2021 at 9:02 am #7914747
Osama Mersal
WPML Supporter since 02/2020
Thanks for contacting WPML forums support. I’ll be glad to help you today.
You can set the alternative text for attachment images to copy among languages by going to WPML-> Sittings-> Custom Fields Translation section, then type “_wp_attachment_image_alt” on the search box, and set it to copy. (Kindly check that attached screenshot)
I hope this reply helps you. If you need further info, please let me know.
Osama
January 24, 2021 at 10:56 am #7915127
ioannisB-7
I can't change it. As you can see from the image it is grey out and has a lock icon.
January 24, 2021 at 10:59 am #7915151
Osama Mersal
Kindly click on the lock icon and the custom field will be unlocked to edit it.
Osama
January 24, 2021 at 11:02 am #7915159
ioannisB-7
Do you think I haven't clicked on the lock icon!
Of course I did but nothing changes...
January 24, 2021 at 11:10 am #7915179
Osama Mersal
Sorry, you are facing this issue. I would need to request temporary access (WP-Admin and FTP)
in order to be of better help and check if some configurations might need to be changed
Your next answer will be private, which means only you and I have access to it.
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if needed. This is also a reason the backup is critical.
Thanks for your cooperation
Osama
January 24, 2021 at 11:57 am #7915283
ioannisB-7
As I have tested, the same issue is also on the test site you have proposed to create on your server: hidden link
Do you have access there or do you want to create an account to the live site?
January 24, 2021 at 12:00 pm #7915285
Osama Mersal
Could you please provide me access (WP-Admin) to the test site?
Osama
January 24, 2021 at 12:09 pm #7915293
Osama Mersal
Thanks for providing the access details. I've checked the test site and followed the previous steps, and it worked correctly. (Kindly check the attached screenshot)
Osama
January 24, 2021 at 12:15 pm #7915321
ioannisB-7
Somehow the issue is resolved now. Thank you!
January 24, 2021 at 12:17 pm #7915323
Osama Mersal
Great to hear that it's resolved now. Thank you for the confirmation. We are always happy to help you.
Have a great day,
Thank,
Osama
January 24, 2021 at 12:28 pm #7915339
ioannisB-7
I am afraid that the issue is not resolved.
I did what you have suggested but as I go to the translated media I still see that the alternative text is empty.
I also went to Settings > Media translation and pressed Start (see image) but again nothing changed.
January 24, 2021 at 12:52 pm #7915443
Osama Mersal
Could you please try to set “_wp_attachment_image_alt” to "Don't translate" and try again?
I've tried this on the test site and uploaded two photos, and the values of alternative texts were displayed like the values of the image title. (Kindly check the attached screenshot)
Here is the post I've created. Kindly try to translate it to see the alt values.
(hidden link)
Osama
January 24, 2021 at 1:11 pm #7915525
ioannisB-7
Please go to WooCommerce Multilingual and try to translate on of my already created products.
It is not working!
January 24, 2021 at 2:08 pm #7915771
ioannisB-7
I think I found what it might be the problem. I am using «Format Media Titles» plugin in order to automatically fill the media title and alt text from media file name. Now I deactivated this plugin and I enable the «Image Attributes Pro» in its position (which does the same thing) and now it works.
