I am trying to make my website in multi-currency, but it is not working. Here is the link to a page where the issue can be seen: hidden link
Multi-currency is not showing on the website.
Why is the multi-currency feature not showing on my website?
How can I fix the multi-currency issue on my website?
Thank you for contacting WPML support, I’m happy to help you with this issue.
After switching to a second currency HUF, I see the price is the same as in the default currency EUR. It could be affected by a third-party plugin or a block of code on your site. I suggest you enable a minimal environment as below and see if it helps:
- Deactivate all plugins except WPML plugins and WooCommerce
- Switch to a standard theme of WordPress
I also need more information on your site by sharing the debug info. If you don’t know how to share the debug info, please follow this article https://wpml.org/faq/provide-debug-information-faster-support/
Your next reply is enabled to share the debug info.
Have you enabled the minimal environment as I suggested? Also, I see that the WordPress Memory Limit is below the requirements. The minimum requirements are 128M, but we do recommend 256M and the debug information of your site shows it set to 64M. Please check this link for more details https://wpml.org/home/minimum-requirements/.
You can increase it by adding the following code in your wp-config.php file, right before the /* That’s all, stop editing! Happy publishing. */ line:
After adding the code you can confirm that the memory was changed correctly from WPML > Support > WordPress > Memory limit.
The topic ‘[Closed] I’m faceing an issue on multi currency not showing’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
