You are updating posts and adding new content but have noticed that images with URLs are no longer visible in the Advanced Translation Editor (ATE) for URL translation. Although images are translated in Media Translation, their URLs remain in the primary language, and this issue does not affect older posts.
We recommend adding the following XML configuration to your WPML settings under the Custom XML tab to address this issue:
<wpml-config><br /><elementor-widgets><br /><widget name="image"><br /><fields><br /><field>image>alt</field><br /><field>link>url</field><br /></fields><br /></widget><br /></elementor-widgets><br /></wpml-config>
After applying this XML, you should be able to see the URLs correctly in the ATE. Please complete the translation of the post and verify if the URLs are translated correctly on the front end.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Osama Mersal 1 year ago.
Assisted by: Osama Mersal.
April 2, 2025 at 2:36 pm
justinK-16
I am trying to update our posts and add new content. Recently, I noticed that images with URLs are no longer showing in the ATE for URL translation. The images are translated in Media Translation, and the image, ALT, and Description are all translated correctly. I believe the image URLs used to be available in the ATE for translation - and are no longer visable. On our other posts which have not been updated and re-translated lately, all works fine. Link to a page where the issue can be seen: hidden link
Images with URLs are not appearing in the ATE for URL translation. In most cases, the image is translating correctly, but the URL remains in the primary language - English for all these images. In one case, the image has been translated in Media Translation but is displayed on our posts in the sidebar widget and is being translated in String Translation after adding it from 'admin screens' -this image AND URL remain in English.
Why are images with URLs no longer showing in the ATE for URL translation?
Why does the URL remain in the primary language even though the image is translated?
April 6, 2025 at 12:56 pm #16901259
Osama Mersal
First of all, sorry for the late reply; it was due to a higher workload.
I need your permission to install the duplicator plugin, which will create a local copy of your site so that I can debug the issue without affecting your live site.
Osama
April 8, 2025 at 8:09 am #16907314
justinK-16
Hi Osama
Yes definitely, please go ahead and install it - no problem.
Thank you
April 8, 2025 at 10:13 am #16908268
Osama Mersal
Thanks for your permission. When trying to upload the plugin, I get the following message. (Sorry, you have been blocked)
Please upload the plugin and let me know so I can create the package. You can download the plugin from this hidden link">page.
Osama
April 8, 2025 at 12:57 pm #16909554
justinK-16
Hi Osama
All done, just looks like it needs a license key.
LMK if you need anything else
Thank you
April 8, 2025 at 3:30 pm #16910201
Osama Mersal
Thanks for updating the plugin. I installed a local copy of your site and was able to see the URLs correctly in the translation editor after the following steps:
1- Deactivate all of the plugins except:
* WPML and String Translation
* Elementor and Elementor Pro
* Directorist plugins
2- Activate the parent theme
3- Edit the page using Elementor in the default language
4- Make a minor edit and update it
5- Update the translation using the translation editor
After the above steps, I was able to see the URLs correctly. Please try these steps on your site.
If the issue is gone, activate the plugins one by one to see which is causing an interaction issue.
❌ Please back up your database before the above test ❌
Osama
April 10, 2025 at 9:39 am #16917567
justinK-16
Hi Osama
I can't do this on our live site - we can't afford for it to not be functioning (even if for just a short while).
So I created another staging site (an exact and up-to-date clone).
However, when I reach your Step 5 - Update the minor edit in the ATE - there is no content showing in the ATE and when I click on save translation, everything then appears in English on the newly translated page.
I activated ALL WPML extensions, but still the same issue.
I can not replicate successfully like you have.
As it seems to work for you, are you able to identify the problem plugin?
or
Can you advise why the ATE no longer shows any of the main content?
The attached images show all the segments that appear (for a post with 3000 words) - no content.
April 10, 2025 at 9:43 am #16917597
Osama Mersal
Would you please share the access details for the staging site?
Osama
April 10, 2025 at 11:24 am #16918106
Osama Mersal
Thanks for the access details. I checked the staging site, but the page seems as if it was not created using Elementor. (hidden link)
That might be why you don't see the page's content in ATE.
Osama
April 10, 2025 at 12:05 pm #16918332
justinK-16
It was created in Elementor, and I made the recent change in Elementor to add the two s's after the bullet point FAQ. See screenshot.
I will try again with another post
April 10, 2025 at 12:05 pm #16918349
justinK-16
Screenshot for your reference.
April 10, 2025 at 12:31 pm #16918512
justinK-16
Ok so i edited another post in Elementor on this staging site:
This time all content appeared in the ATE when doing a French translation.
BUT all URLS that are not internal Posts or Pages are now untranslated (or to describe it differently - the URL in the translation column is a copy of the original language).
See highlighted segments in screenshot.
These have definitely all been previously translated - this can be seen by looking at the same page, BUT on our live site - if you look at the Get Your Guide banners as an example on the French page, you will see they have "/fr" on the end of the URL.
But as soon as I open the post in the ATE their segments will not appear.
April 10, 2025 at 12:34 pm #16918540
Osama Mersal
I added the following XML to WPML-> Settings-> Custom XML tab.
<wpml-config>
<elementor-widgets>
  <fields>
    </fields>
  </widget>
</wpml-config>
After that, I was able to see the URLs correctly in ATE. (Kindly check the attached screenshot)
Please complete the translation of the post and let me know if the URLs are translated correctly on the front end. (hidden link)
Osama
April 10, 2025 at 1:17 pm #16918825
justinK-16
So that now works.
I can see all segments in the ATE
If they were previously translated, they appeared translated in the ATE
They now all appear translated on the frontend.
So, do you suggest that I need to add the above XML to Custom XML - as maybe an issue occurred when I last updated Elementor or WPML (I recently did both product updates).
OR
Activate 1 plugin at a time on the staging site?
If I do this option, do I need to edit a post in elementor each time and then re translate in the ATE to see if there is a conflict?
April 10, 2025 at 1:37 pm #16918919
Osama Mersal
Please add the XML code to your live site, edit the page in the default language, make a minor edit, and update. After that, please check the URLs in ATE.
Osama
