You cannot activate the OTGS Installer plugin and when trying to download the WPML Multi CMS plugin manually, it only downloads an HTML file.
The OTGS Installer plugin cannot be activated because the core plugin is already active. In this scenario, the installer is not required as it is only necessary for the initial setup.
If this solution does not apply to your situation, or if it seems outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by Marcel 2 months, 1 week ago.
Assisted by: Marcel.
February 24, 2026 at 1:24 pm #17846951
milcoP
i cannot activate the otgs installer plugin.
then i try to download the wpml multi CMS plugin manually, but that only donwloads an html file
February 24, 2026 at 1:30 pm #17846994
milcoP
see above and zee the chat i had with malya
February 24, 2026 at 4:11 pm #17847803
Marcel
Could you please try using a different browser?
Are you currently using Safari? I have seen a very similar issue before that only occurred in that browser.
Alternatively, you can install the plugin via the installer:
Plugins → All Plugins → Commercial tab
Marcel
February 25, 2026 at 9:37 am #17850459
milcoP
I installed the WPML multilingual CMS plugin and string translator, but the OTGS installer still doesn't activate.
Does that matter? For what do I need this plugin anyway?
February 25, 2026 at 9:42 am #17850510
Marcel
The installer cannot be activated because the core plugin is already active. In this case, the installer is no longer needed, as it is only required for the initial setup.
Marel
