Supporter timezone: Europe/Tirane (GMT+02:00)
Last updated by Marsel Nikolli 1 year, 9 months ago.
Assisted by: Marsel Nikolli.
November 3, 2023 at 2:29 pm #14726571
vincentM-32
I have changed my website so that the translation in French goes to the .fr domain.
I cannot edit any of my internal links. The French links should send to the French pages, but they send to the original English page instead. I cannot see the links inside the advanced editor or inside String translations, I can't edit them manualy.
If I input a custom URL, it works and I can edit it inside the advanced editor, but I'd prefer if this feature would work so I don't have to edit them all and to keep the link if the page changes later...
November 3, 2023 at 3:53 pm #14727099
Marsel Nikolli
To try to fix this issue, please follow these steps:
- Go to WPML > Settings > Translate Link Targets.
- Click the "Scan now and adjust links" button.
Once the scan is finished, check to see if the issue is still happening.
In case the issue still persists I would require from you to please send me some link of those pages where the issue happens and also how are you creating those pages.
Thank you and please let me know how it goes,
Marsel
November 6, 2023 at 8:20 am #14735295
vincentM-32
Hi Marsel, I already did it, but I tried again.
We are using Elementor to build pages, I tried different links on widget (icons, buttons, containers...), but nothing worked so far. The only links that work are the ones that have customized URL (www.xxx.com) and they are translated inside the advanced editor of WPML.
You can go on the home page (hidden link). Most of the links dont work. Try "Découvrez la ville", or contact us button below.
November 6, 2023 at 9:41 am #14736119
Marsel Nikolli
Thank you for the information.
1) Try to refresh the permalinks on the website by:
- go to WP admin-> Setting -> Permalinks (don't make any change there)
- scroll down to the bottom of the page and click "Save Changes"
After, check if there is any change on the links that weren't translating.
2) Also, please try also clearing the cache of the website and see if it helps.
If none of the above steps works out, could it be possible to check if the issue happens in a minimal setup, meaning:
- set a default WP theme
- enable only WPML plugins
- disable all the other plugins
Note: Before making any changes please make sure you have a full backup of your website, in order to prevent any possible data loss.
Looking forward to your reply,
Marsel
November 6, 2023 at 10:19 am #14736371
vincentM-32
Hey Marsel,
I have tried every options except the disable all plugins, with no success. I need to check with the client if I need to set up a staging site to test everything or if I can live test without the plugins, which will make most of the site not usable.
November 6, 2023 at 11:58 am #14737335
Marsel Nikolli
Sure, take your time, let me know if you have any questions.
Marsel
November 8, 2023 at 8:46 am #14753713
vincentM-32
Hey,
Well I tried disabling everything except wpml and elementor, but it didn't change anything. I still can't see the url containers inside the advanced editor or in string translations.
I changed the edition mode for the home page and put it in editor more, so now I can manually edit the URL on the French home page (I did it for "nos services") and it works, but it's strange that I have access to English page links.
Still, it's a drag having to edit all these links manually, can you check why it's not working?
November 8, 2023 at 3:19 pm #14758179
Marsel Nikolli
To further troubleshoot the issue I would require you try to reproduce the issue on a sandbox site I have setup for you (one-click-login):
On the sandbox site please:
- configure the WPML plugins same as on your website (they are already activated)
- upload only the necessary theme/plugins to reproduce the issue
Please send me instructions on how I can reproduce the issue, step by step guide would be helpful.
Let me know if you have any question or need any help.
Marsel
The topic ‘[Closed] Internal links do not work’ is closed to new replies.
