Last updated by Andreas W. 1 year, 5 months ago.
November 15, 2024 at 10:53 am #16407038
carlosA-49
I'm trying to translate the Header and Footer on my website hidden link using the Houzez theme's Theme Builder. The menu set up in 'Appearance > Menus' translates without issues, but I can't find a way to translate the Header and Footer created with the Theme Builder.
<b>Symptoms: </b>
There is no option to translate the Header and Footer created with the Houzez Theme Builder, and I'm wondering if there could be a conflict with the WPML String Translation plugin or if it was caused by synchronizing the menus in the WP Menu Sync section.
<b>Questions: </b>
Could there be a conflict with the WPML String Translation plugin affecting the translation of the Header and Footer?
Would temporarily deactivating the WPML String Translation plugin to test for conflicts affect the rest of the website’s translations?
November 15, 2024 at 11:48 pm #16410041
Please check WPML > Settings > Post Type translation and set the "Theme Builder" content of Bricks to "Translatable - only show translated content".
Now you should be able to translate your Bricks Template similar as you do for posts or pages using the WPML Translation Editor.
Let me know if further assistance is needed.
The topic ‘[Closed] Issue Translating Header and Footer with Houzez Theme Builder and WPML’ is closed to new replies.
