Last updated by Andreas W. 10 months, 2 weeks ago.
March 26, 2025 at 8:57 am #16860928
sebastianM-71
I was trying to use the WP Menus Sync feature to automatically create translations for 10 different menus across 6 languages for our software product landing pages.
The WP Menus Sync tool page gets stuck on the loading icon and never finishes loading. After some time, it shows an error screen saying 'Site could not be reached'.
Could you please advise on how to resolve the issue with the WP Menus Sync tool getting stuck on loading?
March 26, 2025 at 9:36 am #16861372
sebastianM-71
I was suggested this:
Could you please enable error reporting on your site as I need to see the details of the error log. To enable it, open your ‘wp-config.php’ file and look for ‘define(‘WP_DEBUG’, false);’. Change it to:
// Enable WP_DEBUG mode
define( 'WP_DEBUG', true );
define( 'SCRIPT_DEBUG', true );
After adding the above code, please try to run the WP Menu Sync process again; If this process creates a debug.log file in your site's wp-content directory. Please send me its contents.
I followed that and tried to open the WP Menu Sync page. Again, it's loaded for a couple minutes and then displayed the message, that this page could not be reached. No debug file was created that i could forward according to the developer that conducted the wp-config modifications.
March 27, 2025 at 11:27 pm #16870606
I recently escalated an issue where WPML takes more than 5 minutes to sync around 500 menu items between 10 active languages.
The time limit on your server seems to be set to 120 seconds which means that after trying to sync for 2 minutes you will receive a timeout error.
Please contact your hosting support team and ask them to change the PHP time limit on the server to at least 360 seconds or maybe even more, if possible.
Then test again and let me know the results, please.
March 31, 2025 at 10:57 am #16878769
sebastianM-71
Hey,
Thank you very much for the suggestion. Unfortunately, the issue remains.
The following values were modified:
PHP time limit -> 360
PHP memory limit -> 2048M
Max input time -> 360
After trying to load the WP Menus Sync website, after exactly 4 minutes the "504.0 GatewayTimeout" error message appears again.
What else could we try?
April 1, 2025 at 2:48 pm #16883564
IMPORTANT
I may need to install a plugin called "All In One WP Migration" to create a copy of the website so I can investigate the issue further.
However, I would also be very grateful if you could provide a staging site or a copy of the website from your server for this purpose.
If you have any questions about creating such a staging site, you can consult your hosting provider. Please note that WPML must also be registered on this staging site at https://wpml.org/account/websites/.
If you are unable to provide such a copy of the website for testing, please let me know on this ticket.
Video:
April 3, 2025 at 8:44 am #16890523
sebastianM-71
Hello Andreas,
Thanks again for your support.
Unfortunately, we can not share a temporary access and do not have FTP. Would a video call with screen sharing help too?
Thank you!
April 3, 2025 at 10:08 am #16891155
It is sadly very difficult to investigate such an issue without having access to the site. It would be ideal if you could set up a staging site and provide access.
Please send me a screenshot or video of the details found on WPML > Support.
If possible, please also enable WP DEBUG, then run WP Menus Sync and let me know if any errors were written to the debug.log file.
https://developer.wordpress.org/advanced-administration/debug/debug-wordpress/
Also, investigate the browser debug console when running WP Menus Sync for any JavaScript Errors.
The topic ‘[Closed] Issue with’ is closed to new replies.
