If you're experiencing issues with ACF blocks not functioning correctly, it might be due to a conflict with field names that are commonly used in multiple places.
We recommend changing the field name to something unique to avoid conflicts. For example, if your field name is 'title', you could rename it to 'title_new' or use a block slug like 'title_welcome'. After renaming, you will need to re-enter the field data. If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, please check the related known issues and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket with us for further assistance. You can do so at WPML support forum.
Last updated by Shekhar Bhandari 1 year, 9 months ago.
May 15, 2024 at 2:34 pm
ltuM
Issue with ACF blocks
May 15, 2024 at 3:38 pm #15631547
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Can you change the field slug from title to title_something and see if it helps?
Look forward to your reply.
May 15, 2024 at 5:43 pm #15631977
ltuM
I tried this but it didn't help
May 16, 2024 at 4:59 am #15632802
Shekhar Bhandari
Hello there,
I changed the field name from title to title_new and it's working, can you please check and confirm, it looks like there is some issues or conflict with title names as it can be used at multiple places. Can you confirm?
With the field name change you will need to add the field data again, I suggesting renaming it with block slugs such as title_welcome or similar.
May 16, 2024 at 7:43 am #15633280
ltuM
This seems to work, we'll try changing the all fields
