Last updated by Bobby 1 year, 5 months ago.
Assisted by: Bobby.
October 25, 2023 at 7:32 pm #14664503
evgenyM
Hello WPML Support,
I hope you're doing well. I've encountered an issue with my website that I believe is related to the integration between WPML and the Advanced Custom Fields (ACF) plugin.
When I translate taxonomies on my site, the ACF fields, which are set to "copy" values, are not displayed for the translations. However, if I manually go into each translated taxonomy and click "update", the ACF values then appear. Given the number of taxonomies I have, it's not feasible to do this manually for each one.
I've reviewed the settings in both WPML and ACF and everything seems to be set up correctly. However, the issue persists.
Can you please advise on a solution or provide guidance on how to ensure ACF values are automatically displayed for translated taxonomies without the need for manual updates?
Thank you for your time and assistance. I look forward to hearing from you soon.
October 26, 2023 at 11:35 am #14669887
evgenyM
When I disabled the Advanced Custom Fields Multilingual plugin and created taxonomies, fields with the value copy were displayed in the taxonomy. Now I have turned on this Advanced Custom Fields Multilingual plugin again and started creating translations of taxonomies, but fields such as the icon are not displayed on the front of taxonomies until I click update in the editor of the taxonomy itself.
October 26, 2023 at 9:33 pm #14674507
Bobby
Thank you for the thorough explanation!
Did you see the ACF field options after the taxonomy translations were done?
For example, go to taxonomies and create a brand new one then add the translation, does this issue persist or it does not happen with newly created taxonomies
October 31, 2023 at 10:38 am #14698465
evgenyM
I have now created a new taxonomy, added a translation to it. But the same thing, I see that the field is filled in in the admin panel, but on the front it is not displayed until I click update in the taxonomy.
To create a translation of the taxonomy, I used Taxonomy Translation
October 31, 2023 at 9:19 pm #14703919
Bobby
Thank you,
Bobby
November 6, 2023 at 6:58 pm #14741443
Bobby
I have done a few tests -- I could not reproduce this behavior in a clean environment locally, however, I did reproduce it on your site with 2 test posts.
see the last one I performed here:
It includes a lot of different colors, but when duplicating to French only 2 of them (beige and black) display in the front end, but in the backend I can see all of them listed and assigned correctly.
I also created a post in French directly and while in the edit page I only have a few color options available.
See here:
Based on the above information it looks like there are some inconsistencies with the way the color taxonomy is available in the secondary languages.
Is there any custom element involved in the way this ACF is created in order to display the hex color?
At the moment updating the post does not help nor does deactivating the ACFML plugin.
Please review and advise to ensure I am not missing a step in reproducing this behavior correctly on your site.
The topic ‘[Closed] Issue with ACF Fields Not Displaying for Translated Taxonomies’ is closed to new replies.
