Last updated by Prosenjit Barman 1 year, 8 months ago.
August 15, 2024 at 12:52 pm #16074161
mdC-2
I'm encountering an issue on the checkout page of my WooCommerce store. I've modified the text under the 'Cash on Delivery' payment method, but the changes are not visible. However, when I deactivate WPML, my custom text appears correctly.
Custom text for 'Cash on Delivery' payment method is not displayed when WPML is activated; only the default text is shown.
How can I ensure that my custom text is displayed when WPML is activated?
August 16, 2024 at 8:17 am #16077290
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
I understand the issue you're experiencing. If Dutch is the default language on your site, the changes should immediately appear in Dutch. Could you please go to WPML > String Translation and verify whether the source language of the text you added is set correctly? The string should appear under the Dutch language flag.
If the Source language is not correct there, you can update it by following this guide: https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
However, if the string is showing under the correct source language, the issue might be related to site caching. Could you please clear the caches from your site and browser, then check again? It would also be helpful to check from a different browser or in incognito mode to see if the issue persists.
Let me know the update. I will be happy to help if you need further assistance in this matter.
Prosenjit
August 22, 2024 at 9:07 am #16093646
mdC-2
Thank you for your response.
Dutch is set as the default language.
I cleared the cache of the LiteSpeed caching plugin and checked in different browsers and in incognito mode.
Unfortunately, the issue still persists.
August 23, 2024 at 5:20 am #16097181
Prosenjit Barman
Hello There,
Thank you for trying out the suggestions.
As the issue persists, a closer inspection will be required to understand the root cause of the issue.
IMPORTANT
Best Regards,
Prosenjit
August 26, 2024 at 9:08 am #16103434
Prosenjit Barman
Hello There,
Thank you for sharing the access information.
I was able to fix the issue in your staging site. Please check this screenshot: hidden link
The Dutch text for "Cash on Delivery" was being loaded from the WooCommerce translation files, which is why the manual changes to the title weren't taking effect until the translation file was updated. Here are the steps I took to resolve the issue.
- I navigated to WooCommerce > Settings > Payments and clicked on the "Contant betalen bij ontvangst" method.
- In the Title field, I removed the custom title you had added and replaced it with "Cash on Delivery."
- I saved the changes.
- Then, I clicked on the "vertalingen" link below the title field, which opened the String Translation screen and displayed the title.
- The source language for the "Cash on Delivery" title was English, so I changed the source language to English following this guide:
- After that, I added the Dutch translation, "Betaal bij afhaal."
- Next, I went to WPML > Support > Troubleshooting.
- At the bottom of the page, I clicked on the "Show custom MO Files Pre-generation dialog box" button and then generated the MO files by clicking on the "Generate MO Files" button.
- Once the generation was complete, I returned to WooCommerce > Settings > Payments and updated the Dutch title for the "Contant betalen bij ontvangst" method.
- Finally, I cleared the caches and checked the frontend. This time, the text updated correctly.
Please try accordingly on your main site and let me know how it goes. If you need further assistance or clarification, feel free to let me know and I'll be happy to help.
Prosenjit
The topic ‘[Closed] Issue with Custom Text for Cash on Delivery Payment Method in WooCommerce with WPML’ is closed to new replies.
